Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
January 2025
26 27 28 29 30 31
Old 11-13-2006, 10:20 AM
speed220mph's Avatar
Cobra Make & Engine: ERA 427SC w/427so, ERA GT #2002
Question Front Suspension Shims
Anyone ever have this happen . . . and fix the problem?
Took my ERA GT out for a ride last week and noticed the steering wheel was off center. Upon returning I also noticed an alignment shim laying in the driveway. Putting two and two together, I flipped up the front end and, whoa, all shims were missing from the front of both right-side upper control-arm pivots! There was the reason for the misaligned steering wheel. Wierd because the car didn't pull. Caster had to be off.
Back to the problem: I guess what happened is the pivot bolts loosen just enough to reduce the clamping load on the shims which allowed them to fall out. I now wonder how the shims are clamped between two solid flanges. And from a practical standpoint, I'm also wondering how I can install new shims, then get an Allen wrench into a tight area to loosen and retighten the pivot bolt so they will retain the new shims. Realignment will have to be done. Too bad. It was spot on.
Any suggestions on tools and techniques?
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 11-13-2006, 04:42 PM
Can you post some pictures?
Old 11-13-2006, 05:46 PM
Here's a closeup of the front pivot less shims on the back side. Rear pivot looks the same. I'll post an overall picture, too.
Guess what I'll do is loosen the pivot bolts, fit the shims in real tight, then secure the bolts. I'll have to saw off a short section of hex to fit the socket-head bolt and use a box-end wrench to loosen and tighten bolts. Next stop will be the alignment rack to see where the steering wheel, caster and toe ended up.
Tom
Old 11-13-2006, 05:57 PM
Ron: Here's another try with the pictures:
Tom
Old 11-15-2006, 11:13 AM
Jim Holden's Avatar
Cobra Make & Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Two thoughts:
Post this over on the ERA area so that Bob Putnam is sure to see it or
Call Teddy up at ERA R&D 860-225-6344. It may take him a while to answer so keep trying. Teddy puts the GTs together in his sleep.
Jim
Old 11-16-2006, 06:18 AM
Thanks Jim. Got all the info I needed from Bob. Evidently the car was aligned by somone who didn't use ERA's recommendations on securing the shims, i.e., with cotter pins. They also left out the thrust washers, which allowed the bushing to be abraded, opening up thrust clearance.
As you say, Ted can put these cars together in his sleep. I just hate to bother him. But when I'm in a bind . . .
Thanks again.
Tom
