Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 01-03-2007, 04:57 PM
Tony Ripepi's Avatar
I have in the past contributed to CC
Cobra Make & Engine: TBD
Default GT40 Engine Pics
Hi Guys,
My first time posting in this forum.
I have an SPF GT that has shipped from South Africa and on its way to NorCal and my garage. I am in the last stages of having the engine put together and wanted ask if you guys could post some pictures of your engines. I am trying to decide on valve covers and wanted to see some of your engines in the car for input.
My GT is painted in Gulf livery and has webers on top of an aluminum dart block based 351.
Tony R.
Old 01-03-2007, 07:24 PM
trularin's Avatar
Member of the north
I contributed to CC in 2006
Cobra Make & Engine: A Cobra
Got Pics??
Old 01-03-2007, 07:32 PM
JRoss's Avatar
Cobra Make & Engine: Lone Star Classics #89 Keith Craft Genesis 427 so, stroked to 482, 649 hp. Sabre GT 40 #16 351W stroked to 408, 527hp, TWM stack injection, Fast XFI, G50/50.
Here you go. This might give you some ideas.
John
Old 01-03-2007, 08:28 PM
Cobra Make & Engine: ERA #593,427 S.O.
Default Gt40 Valve Covers
Tony-- You've got my dream car coming your way. Hopefully, I won't be too far behind you on getting one on order!
My favorite valve cover is the classic Gurney-Weslake versions.
Contact Chris Melia--- melCHRISMELIA@aol.com
He's got a shipment arriving this month---I think they're $400/pair.
Regards- Dandy Don
Old 01-04-2007, 11:07 AM
rlearp's Avatar
Cobra Make & Engine: RCR Lola Spider
Lots of ways to go on your engine, congrats on the purchase! Chris is in the UK and definitely has the GW covers as mentioned. There are a lot of engine pictures in the "Member Rides" area here:
http://www.gt40s.com/forum/member-rides/index.html
And a large number located all over the forum if you kick around. Also have a look in the gallery:
http://www.gt40s.com/gallery/index.php
All sort of depends on what you wish to do with your car/motor. Enjoy!
R
Old 01-04-2007, 12:05 PM
Thanks Guys,
Don, I am using an aftermarket drive valve train that sits higher than any of the stock pieces ---- How much room is there with the GW valve covers?
BTW SPF has just increased the price for their roller by $10K.
Where could I see a picture or get dimensions for them?
Rlearp -- Thank you for the links.
Anybody else have pics from the top of the engine bay or the engine?
Tony R.
Old 01-04-2007, 01:15 PM
Default G/w Valve Covers For Gt40
Tony- I would suggest emailing Chris for dimensions. I believe he told me they would clear conventional roller rocker valvetrains; but if you have something exotic like stud girdles, etc. it might be tough. I think somebody makes a spacer for those applications but that might just be one more place for an oil leak. I have seen some pretty neat "sheetmetal" valve covers and there are sources that can "etch" anything, any color, on them. I bought a set of low end Moroso covers for my 427FE and had a custom plate etched in three colors with a Ford logo and 427 script and bonded it over the Moroso name. I got a lot of compliments for very few $$$.
REgards-Dandy Don
Old 01-04-2007, 01:40 PM
Thanks Don,
I emailed Chris and waiting for some dimension info......I am using a valve train that has end stands and girdles along the entire length, the dimensions of the GW covers would be a concern.
Good thought about etching a plate and bonding it onto a roomier set of covers.
Tony R.
Old 01-04-2007, 01:41 PM
JRoss's Avatar
Here is a better shot of the valve covers. Keith Craft can put just about anything you come up on a set for you. These are the ones he delivered with my motor, he said he wanted to put his name on them and I said sure go ahead. There is a good chance I will go with the Gurney-Weslake valve covers at some time if they fit.
John
Old 01-04-2007, 03:32 PM
dynoroom's Avatar
Looking for a different picture, I'll post more when I find it.
Michael LeFevers
Member of the Bonneville 200 MPH Club
1st Production Bodied Car Over 300 MPH
Kugel and LeFevers Pontiac Firebird
Old 01-04-2007, 05:40 PM
ENTDOC's Avatar
Cobra Make & Engine: Kirkham 427 (KMP 266); CAV GT40
I have a set of GW valve covers and they require significang grinding to make fit aluminum rockers. I actually prefer the simple gold or silver 289 steel covers
Old 01-04-2007, 06:41 PM
Club Cobra Member
We have installed the GW covers many times with no issues at all...I guess it depends upon which roller rockers are used......
Old 01-05-2007, 11:47 AM
Thanks for the replies,
Here are two pics of my engine.
Roller Rockers wo valve covers
With Ford Motor Sport Polished Aluminum Valve covers
What do the GW valve covers look like, I was looking at an original set of those heads this morning but, no idea of what the valve covers look like.
TR
Old 01-05-2007, 03:16 PM
Jim Holden's Avatar
Cobra Make & Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
I wasn't aware that Gurney had valve covers to fit standard small block heads. I have GW heads w/valve covers on my ERAFIA (see gallary) but have never seen any other type.
Can someone post a picture?
Jim
Old 01-05-2007, 03:30 PM
Thanks Jim,
I like the look the issue now is will they fit on my engine with the roller rockers.
TR
Old 01-05-2007, 03:55 PM
Jim Holden's Avatar
TR:
I have roller rockers. But please note, the Gurney Weslake (Gurney Eagle)heads are totally different than the normal small block heads. The valve covers on my motor will not fit on a regular small block head.
Jim
Old 01-05-2007, 04:26 PM
rlearp's Avatar
The GW covers that Chris reproduces are for modern SB Ford heads. They are to give you the look of the GW engine.
Old 01-05-2007, 08:04 PM
froggyman's Avatar
Cobra Make & Engine: SPF MKIII, SPO2891, SPO1649
Default What about your trans axle?
TR,
Have you gotten the transaxle yet? A ZF? Where did you get it or where are you getting it from? Let us know about this piece of the puzzle. A few are looking for these transaxles and are not getting them. Just curious.
Good luck on your trans axle search.
Juan
Juan Lopez-Bonilla
Kentucky Cobra Club
2432 Crittenden Drive, Suite 201
Louisville, KY 40217
http://www.kentuckycobraclub.com
juan@lbrdesign.com
502-558-2904
Old 01-06-2007, 09:45 AM
Default Gurney Weslake covers
Hi guys
my valve cover fit the Small block Ford heads and will clear roller rockers, I have sold many sets to GT40 owners without problem.
People that have exotic valve gear or extra high lift cams above 1/2" may need to do some machining.
http://www.gt40s.com/forum/attachmen...1&d=1116662567
regards
Chris Melia.
Old 01-10-2007, 05:34 PM
Chris,
Please PM me with contact information in order for me to get set of your GW valve covers. I assume if they will not work with my roller rockers I would be able to return them, as long as I do not damage/modify them in any way.
Juan,
I have a ZF transaxle sitting on the shelf at the custom shop that is going to build out my GT, the unit I have is a replacement part for the ZF that was used on the BMW M1 with a 3:77 ring gear.
The shop that is building out my car has more ZF transaxels in Stock. The owner is Steve Wilkinson and I did not want to post his contact info until I had his permission, he is in Southern California and has been in the Pantera custom build/rebuild business for 30 years.
Here is a link to his web site and contact info, please let Steve know you got his info from me if you do decide to contact him.
http://www.panterasbywilkinson.com/
Hope that helps,
Tony R.
