Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Tech Talk -- MK1 - MKII - MKIII - MKIV
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
January 2025
26 27 28 29 30 31
Old 07-01-2008, 07:13 PM
I contributed to CC in 2006
Cobra Make & Engine: SPF, 418 Stroker
Default SPF GT40 Oil Pan
Some of the SPF GT40 ads (I think for the MkII) say that the oil pan is furnished by SPF. Can someone explain this? Does the SPF GT require some kind of special oil pan? Thanks.
Old 07-01-2008, 07:20 PM
ENTDOC's Avatar
I have in the past contributed to CC
Cobra Make & Engine: Kirkham 427 (KMP 266); CAV GT40
yes, one that fits between the frame and does not hang lower
Old 07-01-2008, 08:41 PM
Woodz428's Avatar
Cobra Make & Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
The Coupe ,as well, comes with a special pan for similar reasons...it's also baffled.
WDZ
Old 07-02-2008, 11:42 AM
Thanks Doc and Woodsy. I was curious because I just happen to have one of those SPF GT/Coupe oil pans - thinking about putting it on the Cobra because it is an inch shorter (7 vs 8 inches) than my current pan. And yes, it is very nicely baffled. Swinging doors and secret compartments!
Thanks again.
Old 07-02-2008, 12:57 PM
Cobra Make & Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
If it is a GT40 style pan, it's probably made by Aviaid and should be checked for leaks and weld splatter prior to using.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
Old 07-02-2008, 01:02 PM
PANAVIA's Avatar
Cobra Make & Engine: SPF_R_/BRG/FRBoss302/327CI/FordEFI/Under_Car_Exh/
Can someone post a picture, I am curious.
does it require a special pickup tube >?
--Steve
Old 07-02-2008, 01:49 PM
Dangerous Doug's Avatar
Cobra Make & Engine: ERA 289 FIA #2108
You can also get a GT-40 oil pan from Armando in TX. I just ordered a 289 Cobra "road race" oil pan from him. Should be coming in about two weeks.
Armando used to work for Aviaid. When I get back to the office I can post his web site on this thread. Everyone I've talked to about him and his work has had good things to say.
DD
Dangerous Doug
"You're kidding, right?"
Old 07-02-2008, 02:08 PM
This is an Armandos GT40 pan. He will configure it any way you want, as far as oil temp bung and dip stick provision. If you are using a late model block, you will need a dip stick bung in the pan, or a front timing cover with the dip stick provision. You will also need to block off the factory dip stick hole in the block. They come fully baffled and with the correct pickup.
Old 07-02-2008, 02:18 PM
Here's the link to Armando's web site: www.geocities.com/motorcity/flats/1624/
Dangerous Doug
Old 07-02-2008, 08:28 PM
--Steve
Yes, the SPF pan came with a pickup tube and also a dipstick tube. I'll see if I can find some pictures tomorrow.
Old 03-02-2015, 04:33 AM
asasd
Old 03-02-2015, 05:36 AM
Dwight's Avatar
Cobra Make & Engine: RCR GT 40 & 1966 Fairlane 390 5 speed
Smile
you did notice the last post was July of 2008
Dwight
Old 03-11-2015, 06:38 PM
TN Shelby Cobra's Avatar
Cobra Make & Engine: Superformance # 1774 / 392 Stroked Windsor
Dwight
Dwight, I think Jerry still has the pan! ( I thought I saw it the last time I was at his shop) Mark
