Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Tech Talk -- MK1 - MKII - MKIII - MKIV
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 03-06-2007, 12:07 PM
speed220mph's Avatar
Cobra Make & Engine: ERA 427SC w/427so, ERA GT #2002
Default ERA Steering-shaft Bushing Loose
Has anyone had a problem with the upper steering-shaft bushing working loose from it's housing . . . and have fixed it? Just wondering because I've run into the problem. It got my attention real fast as the steering wheel/shaft all of a sudden had a lot of side-to-side movement with an accompanying banging noise. As a temporary fix, I reached under the instrument panel and found the steering-shaft bushing that slide out of its housing, then pushed it back into place. It happened again this AM, so I'm looking for a permanent fix. Any suggestions will be appreciated.
What I've done in the interim is to clean the bushing OD, coat it with Loctite, then slide it back into place. Maybe the Loctite will do the trick. But if it comes loose again, I guess it will require dropping the steering shaft to make a permanent repair since the temporary fix didn't work.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 03-06-2007, 02:15 PM
Jim Holden's Avatar
Cobra Make & Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Speed:
Have you checked with Bob Putnam at ERA directly? It would seem that there should be some sort of retainer/clip/bump or sump'n like that... or should be. I would suggest you e-mail him (if not call) directly.
Jim
Old 03-06-2007, 03:43 PM
Thanks Jim: Call Bob all the time, so I thought I'd give him a break and try the "open market" to see if anyone had the same problem with their car. When all else fails I'll make the call.
Tom
Old 04-25-2007, 05:25 PM
A good application of Loctite seems to have secured the bushing.
Tom
Old 04-25-2007, 05:42 PM
speed,
All due respect to your fix but I'd regard this as a safety issue of the first order.
Please replace the bushing ASAP. I did mine about 5 years ago with less apparent play than yours. Bob sent a new one and it's not hard at all. Presto, no vibes.
Picture about 110 MPH and the wheel clanging around in your hands.
Just my .02
Chas.
Old 04-26-2007, 06:48 AM
Default Bushing fixed; shifting problem
ERA Chas: No problem now, although the steering wheel moving around at high speed can be a bit troublesome at high speed. The bushing wasn't worn, but the press in the housing that retained it was lost. Once fixed in place with Loctite the bushing stays in place and the steering shaft has virtually no play, so all is OK.
On another note, the 3--4 shift is difficult, however all others are smooth . . . ZF transaxle is used. Once the transaxle is warm, the shift is a bit easier, but still a little difficult. I seems like the synchros are ok, so I suspect the problem is with shift likage adjustment. Have you experienced any such problem? If so, got any suggestions on a cure?
Tom
Old 04-26-2007, 09:54 AM
See My Journal Visit my Photo Gallery
I have in the past contributed to CC
Cobra Make & Engine: Kirkham #259
Here's a steering shaft fix after we had a similiar issue.....
http://kmsac.com/index.php?option=co...&topic=278.405
Morris
Morris
Old 04-26-2007, 10:21 AM
Nice. You didn't spare any $$$ when making this fix. As for me, I'll stick with a sleeve bearing (bushing) because there won't be any danger of brinnelling or funds depletion. It ain't broken now, so I don't need to fix it.
Tom
