Go Back   Club Cobra > Engine Building, Tuning, and Induction > Ignition
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 09-27-2011, 07:28 PM
Cobra Make, Engine: A&C Cobra, 521 CU BBF, Holley ProJection, T56 Magnum, 3.5:1 TruTrac 9-inch
Default points to electronic
hey folks,
im working on restoring a 66 mustang. i have a points style 289 distributor. has anyone used an electronic module to convert the 289 points style to electronic? im looking for something like an HEI controller module that would go inside the distributor. does pertronix make something like that to retrofit? or maybe i'll stay with the points - that way I can drive out of town in the 1966 when the super solar flares hit :P
Driving fast keeps you young. Just ask Einstein....
Old 09-27-2011, 07:31 PM
Cobra Make, Engine: era 427 side oiler
hello: have several small block fords and point type dist..i can only recommend petronix! i feel they are the best! domenic
Old 09-27-2011, 08:01 PM
Rick Parker's Avatar
Buy a rebuilt distributor for a 75-76 302 and swap the internals into your 66 Distributor body, very easy.
You can even add the late syle cap if you want to:
[IMG][/IMG]
Rick
Old 09-27-2011, 08:49 PM
thanks for the tip on the 302! i knew someone would have a simple solution
Old 02-21-2012, 06:47 PM
Earl J's Avatar
Cobra Make, Engine: GT350,289 w/48IDA Webers
Send a message via AIM to Earl J
[IMG][/IMG]
Rick,
Do you have a Ford cross reference part number for that Distributor cap? Does it fit an older 1965 HP289 mechanical advance body? Your picture is telling me yes, but I thought to ask.
Thanks,
Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
