03-08-2009, 07:11 PM
TN
Inglese™ Weber Performance Camshafts by COMP Cams®
Inglese™ announces 16 new hydraulic roller camshafts designed specifically to work with Inglese™ Weber induction systems and Ford, Chevrolet and Chrysler engines
Inglese™ Weber carburetors offer outstanding performance and throttle response, as well as an incredible underhood appearance. But until now no manufacturer had created camshafts designed specifically to optimize this classic high performance induction system. The new Inglese™ Weber Performance Camshafts by COMP Cams® are designed to enhance the power and drivability of these systems; Inglese™ having worked closely with the COMP Cams® engineering staff to create the most advanced camshaft designs possible. As a result, Inglese™ announces the creation of 16 hydraulic roller cams for Ford, Chevrolet and Chrysler engines.
The secret behind these camshafts is the strong vacuum and signal they create; key ingredients to delivering peak uncompromised Weber performance. While most camshafts are designed for plenum-type 4-barrel carbs or electronic fuel injection, the Inglese™ Weber Performance Camshafts by COMP Cams® were designed from a “clean sheet of paper” for the best performance and drivability possible. The new Inglese™ Weber Performance Camshafts by COMP Cams® are offered in two performance levels for each engine platform, including four popular Ford engines, Small and Big Block Chevrolet, as well as Small Block Chrysler engines.
For more information about the Inglese™ Weber Performance Camshafts by COMP Cams® or any other Inglese™ product, call us at 1-866-450-8089, or visit us online at www.inglese.com.
