Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Keith Craft Racing
March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 10-28-2006, 07:07 PM
JAC's Avatar
JAC JAC is offline
Cobra Make, Engine: Classic Roadsters II
Default crank girdle
Hey Keith, Do you use a crank girdle on your 408 engines? I read somewhere that engines using production blocks that make over 500HP should use crank girdles. Thanks.
Old 10-28-2006, 07:33 PM
Dwight's Avatar
Default Questions for KC
Hey Keith
Should I use a girdle on a 354/ 5.0 with close to 450 plus ( I hope ) HP? I have see ads for alum, steel and tool steel main girdles. Which is the best? Dwight
Coach is going to install the 461ci you build for him Sunday.
599.5 HP and 619 tq
Old 10-28-2006, 08:00 PM
Default Main Girdle
We have run the 351W blocks up to 600HP without the girdles without any problems. We will use one if the customer plans on running nos or a blower. I do not feel that in a 500HP situation that you will have not any problems. Thanks, Keith
Keith C
Old 10-29-2006, 05:28 PM
JAC's Avatar
JAC JAC is offline
Default girdle
Thanks Keith, I think I'll be ordering your 408 around the 1st of the year. Jerry
