April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
  #261 (permalink)
Old 11-12-2011, 07:08 AM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Originally Posted by kgs365 View Post
Can you post a picture of the fuel log set up you have...please..I'm not liking the set up I have it doesn't look right under the turkey pan
I made my own fuel log and after purchasing all of the reducers, etc. i could have easily bought one, but the problem i ran into is that nobody makes a fuel log which has -8 line that feeds into the -6 lines on the carb. So, i ended up using -8 to -6 reducers on the ends and -6 t fittings.
  #262 (permalink)
Old 11-12-2011, 07:11 AM
Originally Posted by Avmaviator View Post
Ironman is spectacular! Like Chris said, I flew down to Birmingham on Thursday to see the car and enjoy a nice AL fall day (it was cool but much warmer then the 31* in Chicago with light snow ) Thanks again Chris!
Chris did a fantastic job putting this car together. It looks great, sounds fantastic, and it is a beast. It is quite something to be seated behind 527 screaming cids! Once the car hooks ups all the way (usually in second gear it seems, but it got grip in first too), you can feel it grip/squat down, and bang, you just got launched off a canon.
I have pictures, and good videos too, but I need to figure out how to go from a dvd to youtube.
Thanks Arnaud! It's good to have approval from a fellow car enthusiast that understands the amount of time that goes into a build like this.
  #263 (permalink)
Old 11-15-2011, 10:36 PM
Default Finishing Touches
Now that i have 200 miles on the car, it is time to put on the finishing touches. I started last weekend with the tires and I have been working on the sidepipes this week as time allows. I managed to make it through polishing the 4 passenger side header tubes yesterday and this evening i spent 6 hours making the aluminum heat shields to go around the sidepipes.
First, here are some pictures of the hood scoop and hood after the stripes were repainted. The scoop pulled away from the hood this past spring when i was working on the car. Apparently the rivets were not long enough and did not fasten the scoop properly to the hood. Plus, they were painted together and paint pooled around the corners of the scoop, so when it pulled away it took a lot of paint from the hood with it. Since the underside just had an uneven overspray of blue, i decided to strip it and make it bare brushed aluminum.
Stripes repainted on the hood. I decided to buff the hood myself to save a few bucks.
Goodyear Billboard Tire lettering-The letters on the right rear tire were the most worn. I thought about making a template, but instead i just decided to tape the tires, carefully cut around the letters, and respray them.
  #264 (permalink)
Old 11-15-2011, 10:44 PM
Sidepipe polishing and Heat Shields
Making a template for the heat shield
And installed. I am sure some will not care for it, but they are necessary. There is no way to protect the paint around the cutouts and the paint chipped a little when i enlarged them to fit the header tubes. Cinema Vehicles or Kirkham only cut them just enough to fit the non functional pipes through. It took me about 3-1/2 hours to make each heat shield.
  #265 (permalink)
Old 11-16-2011, 03:55 AM
FUNFER2's Avatar
Who's tire paint did you go with ?
I have the paint from Ranger, but haven't used it yet.
Also, how did you adhere the heat shields ?
Ranger Tire Paint — Testimonials
Regards,
Kevin
  #266 (permalink)
Old 11-16-2011, 05:14 AM
I used stencil paint that was left over from a midyear Corvette restoration. It adhered really well, surprisingly. I tried some of the tire paint that comes in a pen and brush paint from the hobby store, but both were too thick, looked clumpy, and showed brush marks.
The heat shields are currently held in place by 4 screws, one at each corner. I plan on using small pop rivets to secure them once the pipes are fully polished and assembled.
  #267 (permalink)
Old 11-16-2011, 05:38 AM
FUNFER2's Avatar
Since I have the Ranger paint, I'll follow their instructions, so lets keep in touch and see what works best. I don't know when I'll get around to paint them ?
Regards,
Kevin
  #268 (permalink)
Old 11-22-2011, 06:57 AM
30 hours total last week polishing the pipes, making heat shields, and removing and reinstalling the header tubes and sidepipes. I had no idea it was going to take so long to polish the pipes!!!! I only had one mishap with the high speed buffer and fortunately i still have all my digits and none of the parts were damaged.
Before
After
And just in case you are wondering what is inside. I am still scratching my head as to why these are so incredibly expensive, but they sound good and the muffler portions stay surprisingly cool.
  #269 (permalink)
Old 11-22-2011, 07:28 AM
FUNFER2's Avatar
You'll love the stainless as I do, over mild steel. What's inside the muffler ?
Mine are louvers. I build these highly polished 304 stainless in a kit form for any cobra, vette, hot rod etc. I think they clean up easier than a coating. They will last for many,....years over mild steel.
Anyway, they look great buddy.
Gilmore Side Pipe Kit pictures by 427HISS - Photobucket
Regards,
Kevin
  #270 (permalink)
Old 11-22-2011, 08:13 AM
That piece sitting next to the muffler tube is all that is inside. Just a screen that inserts into the material inside of the muffler. I am not sure if it is fiberglass packing inside of the muffler or something else.
  #271 (permalink)
Old 11-22-2011, 08:20 AM
FUNFER2's Avatar
The photo of what ever's inside the muffler looks restrictive. One of my customers muffler had this inside. Wow, talk about restrictive.
Regards,
Kevin
  #272 (permalink)
Old 11-22-2011, 11:15 AM
Avmaviator's Avatar
Cobra Make, Engine: Kirkham #647 brushed
I believe the packing is stainless steel wool if I remember correctly from my Kirkham visit. It is supposed to last longer and not break down like fiber glass does.
The pipes look really good Chris. Looks like a lot of work but totally worth it when you see the result.
  #273 (permalink)
Old 11-22-2011, 12:06 PM
Very nice built ! Congrats ! Where did you get this sidepipe- kit from ? Looks perfect !
  #274 (permalink)
Old 11-22-2011, 12:50 PM
FUNFER2's Avatar
Do you mean me ?
If so, we make them. The primaries extra long for a custom fit. All you need is your 4-hole flange to match the one on your headers. Like Chris mentioned, stainless is expensive, but they last much longer, look and sound great. If you want more info, PM or email me as I don't want to work over his thread.
Again Chris- beautiful cobra build and great workmanship !
Regards,
Kevin
  #275 (permalink)
Old 11-22-2011, 12:51 PM
Its just a straight through pipe with packing material around it. It really isnt restrictive at all. I guess my fuzzy pictures is showing the wrong thing. Look at the picture of the pipe on the ground. At the front of the pipe is the collector that i removed and next to the sidepipe is the mesh tube that inserts into the stainless pipe. It simply slides down inside of the stainless steel pipe and has sound dampening material around it. The mesh pipe appeared to be around 2-1/4 to 2-1/2 in diameter and is straight through. The design gives the exhaust a nice low rumble, but it still loud and does get very loud under full acceleration, but it is not like some of the glasspacks that are in my opinion obnoxious and will make you want to rip your ears off. Also, the mesh does not produce a flappy sound at idle while cruising, it keeps that nice low pitch. However, it does flap when backpressure is present, but it isnt terrible.
  #276 (permalink)
Old 11-22-2011, 12:54 PM
FUNFER2's Avatar
It is pretty fuzzy. lol
Doesn't the stainless sound great over mild steel !
What did you do for hangers ?
My first ones were just 1/4" thick straight stock welded to the outer shell of the muffler. It ripped out after 20 miles, so we changed to out present hanger that conforms to the muffler and about 3" long. No issues now.
Regards,
Kevin
  #277 (permalink)
Old 11-22-2011, 01:12 PM
You I didnt even think about the stainless contributing to the sound, but now that you mention it, i am sure it makes a difference. I certainly know there is a big difference in how an internal fuel pump sounds inside of an aluminum gas tank vs a stainless tank.
  #278 (permalink)
Old 11-22-2011, 01:18 PM
FUNFER2's Avatar
Yes, much deeper and raspy tone. I would have never thought about a pump sound difference in a fuel tank. Interesting.
Regards,
Kevin
  #279 (permalink)
Old 12-10-2011, 11:54 PM
took my exhausts apart today..... - Page 2
this is the stuff i used, ( acustafill ). I dont know how available it is over there but i was really impressed with the difference it made. The first thread is the one about my exhausts specifically if you go to the 4 page you can see how easy it is to install.
Sidepipe / Silencer Packing Material - Acoustafil
  #280 (permalink)
Old 12-11-2011, 05:52 PM
FUNFER2's Avatar
We have to join that site to see the pics. Can you just post some here on CC ?
Regards,
Kevin
