questions
- » Blogs
- » Image Gallery
million posts!
March 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
07-20-2010, 04:38 PM
Ma
Cobra Make, Engine: Kirkham 592
I just noticed I have a celcius water temp. What should the temp be?
Thanks. It is running at 100
Advertising
07-20-2010, 04:49 PM
va
Cobra Make, Engine: BDR #250
c to f converter
07-20-2010, 04:53 PM
PA
formula...
C=5/9 (F-32)
so....100=5/9(F-32)
900=5(F-32)
900=5F-160
1060=5F
212=F
07-21-2010, 05:16 PM
mine runs between 98 and 105 depending on outside temp. When I was setting the timing, it got to 110. (3500 rpm and no wind)
07-21-2010, 05:31 PM
I run about 90 c with a 180 T-Stat on the highway. It will certainly creep up to 100-105 even a 110 around town on a hot day.
07-21-2010, 05:48 PM
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
My FE runs dead on 90 Deg C using 90/10 water/coolant mix. 50/50 mix puts me up aroung 100 deg C
07-21-2010, 05:51 PM
AZ
You'll be in the ball park by doubling the C and adding 30 for F. This is just for a guesstimate. Obviously, 100C doesn't fit the rule, nor does 0C since that is 32F. close, but no cigar.
Karlos
07-21-2010, 08:08 PM
Ga
Cobra Make, Engine: Superformance aluminum427
Gauge
Mine runs about 80 to 85 C its a 484 FE, I do not want mine anywhere near 100C, if I get in slow traffic or a parade I cut my fans on, I have replaced to headgaskets when I let it get over 100C. I have a Shelby block an Eldebrock heads, no problems if you keep it under a 100C
07-21-2010, 09:42 PM
CA
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
Karl, your rule works at 0 C because 0 C actually is 32 F. I don't worry about converting the C to F all the time, but then I don't understand my water temps. I've got an 85 C (185 F) thermostat. I would expect the water temperature to warm up to 85 C and then drift up and down as the cooling load changes. Seems like once warmed up, the temp should not go any lower than 85 C. I don't understand when it is 60 F or cooler, the temp gauge barely gets above 50 C. I use cardboard to partially block the radiator, but that only raises it to 60 C. I'm pretty sure the temp gauge works because it can get up to 90-ish when no air is getting pushed through the radiator.
07-21-2010, 09:46 PM
Celsius Gauge Conversion
Knowing that 100C = 212F, use this as your basis, and keep in mind that a 5 degree change on the C gauge equates to a 9 degree change in F (From the conversion formula F = 1.8C + 32; 1.8 x 5 = 9)
Hence:
85C = 185F
90C = 194F
95C = 203F
100C = 212F
105C = 221F
110C = 230F
Note that the high and low values of the range above are easy numbers to equate and remember for both scales (85=185; 110=230). You could print this out and tape it to your dash, but I imagine you will be ‘thinking in Celsius' quite easily once you find your comfort zone of operation there.
Hope this helps. - Jody
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
