January 2025
26 27 28 29 30 31
Old 07-21-2010, 02:17 PM
Cobra Make, Engine: Kirkham 592
Default My car is reading a little low on the voltage with the engine running.
What are you guys running? Mine is around 12.5
Chris
Old 07-21-2010, 02:28 PM
Tommy's Avatar
If it's showing the same voltage with the engine off, at idle and revved to 2,000 RPM, you have a problem. Mine shows 14-15 volts while cruising at 2,400 RPM.
Tommy
Previously owned EM Cobra
Old 07-21-2010, 02:30 PM
twobjshelbys's Avatar
In addition to the above, try switching on and off your aux fan and see if it changes. It might not be a steady state difference but you should see the step. If not, yep, problem.
Old 07-21-2010, 04:40 PM
How about just turn up the idle speed a tiny bit?
Old 07-21-2010, 04:48 PM
Send a message via MSN to CowtownCobra
If you don't have a 3rd gen Ford alternator, get one...
Old 07-21-2010, 06:15 PM
12.5 with 3 fans and two blowers on. 14.5 with nothing on. I had a problem where it stopped charging and after 3 regulators and 2 alternators, something told me that these were not the problem. We tightened a bunch of wire connections (like battery, starter, etc) and the problem went away. Of course we traced wires, etc and it took 3 weeks, but it ended up being one of those. we also replated the starter "lug" with all the wires going into it.
It took 3 weeks, but it looks like it was just lose wires
