February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 09-13-2010, 03:16 PM
xlr8or's Avatar
Mine is automatic using the low speed circuit. A/C kicks it into high gear and keeps it running anytime the A/C is on. Manual switch on the dash kicks it into high gear if the A/C is not running.
  #22 (permalink)
Old 09-13-2010, 05:02 PM
Both. My engine runs a little warm, particularly the oil, which can be 15-20C above water temperature. I am working on fixes. In the meantime, I find that, in hot engine conditions (high ambient temperatures, stop and go, mostly go but not freeway, with high rpms between stops), turning the fan on manually, so it runs constantly, reduces my water temperature by 15-20C and my oil temperature by 10-15C. I turn the manual fan on only after automatic fan has come on (and off) and temperatures are higher than I want. I have an SPF, two puller fans, fans are on in manual mode whether engine is on or off, hot or cold, so remember to flip switch to automatic or off when you shut car down to avoid battery drain (fan noise is a reminder).
  #23 (permalink)
Old 09-13-2010, 05:35 PM
Send a message via MSN to CowtownCobra
Manual, it would run all the time anyway. Only time I ever turn it off is when futzing with the elec system. Same reason I have a fuel pump switch and a battery cutoff
