January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 11-23-2010, 07:19 AM
Yes it needs a drilled and tapped hole in the shaft to line up with the cancelling cams. Then that needs a slot and a short strip of metal. The steering is only 3 turns lock to lock on a Cobra so the screw needs to hold the blade right between the cams or else you need a whole turn of the wheel to cancel directionals. There's some pics of the shaft here http://www.csxinfo.net/web/modules/s...p?topic=1044.0 I have put them in several cars so if you need a hand with it let me know.
Thank you!
  #22 (permalink)
Old 11-23-2010, 07:25 AM
mickmate's Avatar
No worries, it's not just a matter of looking goofy driving along with your directional on. It's a real safety hazard as it's not easy to see directional lights inside an open car in daylight and people pull out in front of you if you've got the directionals on.
mickmate
http://www.actoncustom.com/
  #23 (permalink)
Old 12-08-2010, 07:38 PM
mickmate's Avatar
Found my pic of it with a quick install ramble.
http://www.csxinfo.net/web/modules/s...p?topic=1296.0
mickmate
