January 2025
26 27 28 29 30 31
Old 09-17-2010, 02:11 PM
Default Self Canceling Turn Signal
Is the turn signal supposed to self cancel? Also, does your steering hub rub the turn signal housing making a funny rubbing sound? (only heard with engine off)
Old 09-17-2010, 02:33 PM
RodKnock's Avatar
Nope and nope.
Old 09-17-2010, 03:11 PM
dcdoug's Avatar
Actually, I understand there are some adjustment screws so you can get it to self cancel. One of these days I'll get around to messing with that so mine will self-cancel....
www.partskeeper.com
Old 09-17-2010, 03:24 PM
JST4FUN's Avatar
Cobra Make, Engine: SOLD-SPO2660, Southern Automotive 406FE, TKO-600
Mine supposedly has an adjustment. One side cancels, the other doesn't. I've read the adjustment procedure, but haven't gotten around to it as yet.
Joe
Have fun and enjoy life, because when it is over, it is too late!
Old 09-17-2010, 03:43 PM
RodKnock's Avatar
Oh, come on now. Just leave your turn signal on just like all the other old man do.
Treat it like your fan switch. Turn it on and off when you can.
Old 09-17-2010, 03:57 PM
dcdoug's Avatar
I resemble that remark.
www.partskeeper.com
Old 09-17-2010, 04:17 PM
Cobra Make, Engine: Kirkham #625 427S/C, 468 ci Al block, 615 HP
The switch can rub on the back of the steering wheel; sounds like yours is. Mine did too as delivered If you loosen the set screw on top you can slide the switch away from the back of the wheel and eliminate the contact.
I guess I will have to play with the switch now and see if I can activate the self canceling.
Mark
Old 09-17-2010, 06:01 PM
Mark
what do you mean by screw on top? I will look into all of this as my winter project. Thanks!
Old 09-17-2010, 09:27 PM
mickmate's Avatar
There's a phillips screw that locks the switch assembly to the column. If you loosen the screw it will adjust around and in and out a little to get the clearance you need off the wheel hub. If you pull the steering wheel off there is a screw or bump of some kind sticking out of the steering shaft. It will be centred on the cams that come out when you put the switch on.
mickmate
http://www.actoncustom.com/
Old 09-18-2010, 05:43 AM
cool, I'll check it out thanks!
Old 09-18-2010, 06:55 AM
There are at least two adjustments that may help. Here is a photographic illustration of the adjustment that mickmate describes: http://www.craigscobras.com/tips/blinker/index.htm The other thing you can do, as described in some of the posts above, is loosen the Phillips head screw behind the turn signal lever, then adjust (rotate) the signal lever assembly left/right (or up/down) to best position. The lever in my SPF was at the 3 o'clock position. Recommended position is closer to 2 o'clock. These two adjustments helped with my cancellation issue, but it still was not right. I spent some money to buy a new switch indicator (not cheap), available from Hillbank Motorsports, http://www.shelbyshop.net/product_in...ucts_id=156173, had that installed, and my turn signal now cancels perfectly on both sides. This is obviously not a performance issue, but it bugged me until I got it right.
Old 09-20-2010, 04:21 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Where can i buy the switch? I was going to purchase it from Finishline, but i dont think they carry the part any longer.
Old 09-20-2010, 08:17 PM
They are all over ebay, some better quality than others:
http://cgi.ebay.com/ebaymotors/VW-Vo...e#ht_500wt_956
Old 09-20-2010, 09:16 PM
RON N BKFLD's Avatar
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
I clamped 2 tabs to the steering shaft. They hit the canceling tabs on the signal unit after your turn. Adjust the shaft tabs to where you want them, & clamp them tight. Works great. Did it on both cars. Ron
RON N BKFLD
Old 09-21-2010, 09:06 AM
Im not trying to hijack your thread and i apologize for posting in it, but which year model VW switch do i want to purchase? I assume the 65 and before since it functions only as a turn signal switch and not a dimmer switch as well
Thanks
Old 09-21-2010, 09:52 AM
Thanks
I think any 62-67 Beetle will work. Local auto parts stores carry them as well in both AC Delco and BWD.
Old 11-23-2010, 05:29 AM
I pulled the steering wheel, adjusted the turn signal switch so it does not rub the steering wheel hub anymore. That was easy. But I did not find any screw on the hub to adjust to make it self cancel. The switch itself does have a provision for it, but the steering wheel hub does not. Perhaps, another hub would have this provision.
Old 11-23-2010, 06:41 AM
mickmate's Avatar
It's not on the hub it's on the shaft. They need a small flat with a tapped hole.
mickmate
Old 11-23-2010, 06:46 AM
so the shaft itself should have a threaded hole there already or is it something I would have to drill?
Old 11-23-2010, 07:14 AM
mickmate's Avatar
Yes it needs a drilled and tapped hole in the shaft to line up with the cancelling cams. Then that needs a slot and a short strip of metal. The steering is only 3 turns lock to lock on a Cobra so the screw needs to hold the blade right between the cams or else you need a whole turn of the wheel to cancel directionals. There's some pics of the shaft here http://www.csxinfo.net/web/modules/s...p?topic=1044.0 I have put them in several cars so if you need a hand with it let me know.
mickmate
