April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 11-19-2010, 10:23 AM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Kirkham TKO Trans Mount??
When do i weld in the Transmission mount tabs to the crossmember? Before or after i install the engine and transmission. Im guessing after i install the transmission and engine so that i can get the correct angle on the driveshaft.
Old 11-19-2010, 03:14 PM
Nevermind! The Kirkhams already welded them in place on the frame. Thank you David and Steve!!!!
Old 11-26-2010, 09:09 PM
David Kirkham's Avatar
Original Shelby Owner
They are welded on all our cars now. You would have to special order it without the mount if you wanted it that way.
David
