April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 06-16-2011, 06:36 PM
David Kirkham's Avatar
Original Shelby Owner
Default Cracked Oil Pan--Fatigue
Guys,
The oil pan on my car cracked and finished my track day early
I wanted to show you guys how a weld can fail in "fatigue." Fortunately, someone noticed oil was POURING out from under my car after I had just gone out and only taken one lap. I pulled into the pits (leaving a trail) and figured a line must have come loose. When I jacked up my car I realized track day was over.
David
Old 06-16-2011, 06:38 PM
Here is a close up of the crack. The oil was literally running out.
Old 06-16-2011, 06:41 PM
Old 06-16-2011, 06:50 PM
Avmaviator's Avatar
Cobra Make, Engine: Kirkham #647 brushed
That is pretty wild that 1) it cracked so "neat" and straight, and 2) that oil was pouring out instead of sepping out.
Are you going to reweld it or put a new one on?
Old 06-16-2011, 07:20 PM
We don't have the time to fix it--too many other projects. We put another oil pan on already. I will probably just sell this one at garage sale cheap. This induced us to make our own ALUMINUM oil pans
The oil was pretty hot so it was POURING out.
David
Old 06-16-2011, 09:02 PM
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
David,
What would you want for it? Been looking for a pan for my build and I don't mind putting a little elbow grease in to re-weld that pan.
Thanks, Curtis
Old 06-18-2011, 05:44 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Do you think that crack was caused simply from vibration or??? Aviad or Armando pan?
Old 06-18-2011, 06:41 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
The bottom of the pan might have been moving up and down, driven by engine vibrations. Like a drum head. That could explain the neat edge crack.
Dave
Old 06-18-2011, 06:45 PM
David, some info please. I checked your site and none there.
Perhaps a little feature post on this new pan?
Construction?
Pick-up?
Tray?
Scraper?
Availability?
Price?
Hey-there's no 'social' icons on the bottom here! All gone?
Chas.
Old 06-18-2011, 06:59 PM
*13*'s Avatar
Good to hear it didn't destroy the engine. Looks like a nasty little hole
ERA FIA 2088
Old 06-18-2011, 07:26 PM
Jerry Clayton's Avatar
Thats a common place/way for an an oil pan to fail---oil pans will oil can---and the stress point is at the weld line where two flat sheets come together at 090*and are welded---especially with alum--there are so many different alloys of sheet stock, so many different welding rod alloys and then add in the welding technique and you have a sure to happen failure--just depends on how long it'll take
Old 06-19-2011, 11:08 PM
Rick Parker's Avatar
Gas weld looks too cold, probably butt welded. He needed to not have the pieces flush when he welded, the bottom piece should have been held back half the thickness. That way it's more like a fillet weld, lots stronger. Harmonics play a big part.
Rick
Old 06-20-2011, 10:39 AM
Cobra Make, Engine: FFR, 347, 462 hp, 4 barrel
If it had been welded correctly then the weakest area is the "Heat Affected Zone" or HAZ. A failure in the HAZ would be next to the weld not through the middle of the weld. Something was not set up correctly or poor penetration, IMO.
Note, simply re-welding would likely result in the same failure, not worth the risk IMO.
Lee
Old 06-20-2011, 02:31 PM
RodKnock's Avatar
Not sure if it's an Aviaid, but the original Aviaid oil pan for my engine developed a leak at a weld immediately. If I remember correctly, mine was a pinhole at a bottom corner. And I heard from one other person with the same problem that I had.
Old 06-20-2011, 03:29 PM
Originally Posted by Racer_X View Post
David,
Thanks, Curtis
I think they are $600. I'll let it go for 1/2 price.
David
Old 06-20-2011, 03:31 PM
Indeed--vibration. We have had several pans crack over the years. So, we just decided to make our own.
David
Old 06-20-2011, 03:35 PM
Construction?
Pick-up?
Tray?
Scraper?
Availability?
Price?
We will post on our new oil pan when we finish the prototype. We just haven't quite finished it yet.
Aluminum
Same pick up as original (Aviaid).
Modified tray and scraper
Not available yet
Price--close to the same.
I am not sure about the social icons stuff...Jamo?????
Ron????
I AM on facebook (all day every day).
David
Old 06-20-2011, 03:36 PM
The original pans is made from steel. It has been zinc plated.
David
Old 06-20-2011, 03:38 PM
Yes, the weld did look a bit cold to me too. I agree joint fitment is critical to a good weld. Harmonics and vibration are really difficult to control, however.
David
Old 06-20-2011, 03:40 PM
Oil pan sold.
David
