08-03-2011, 04:56 PM
FL
Cobra Make, Engine: Kirkham #570 w Shelby FE
The 3M and Permatex weatherstrip adhesive is just contact cement.
Problem is after it's been sitting on the shelf a while the solids drop. In a can you can re-mix it, in a tube you can't.
BTW I do recommend the 3M weatherstrip solvent, it's some mix of Acetone, Naphtha and some other stuff and works very well.
Baseboard adhesive also works well (similar to the gel contact cement).
