questions
- » Blogs
- » Image Gallery
million posts!
April 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
11-12-2012, 07:07 AM
Ut
We use a small piece of rubber fuel line with stainless hose clamps.
Advertising
11-16-2012, 01:09 PM
MD
If you are running original Lemans rods with cap screws, you may need to adjust the scraper for a bit of additional clearance.
www.partskeeper.com
06-12-2013, 07:49 AM
MD
A question: the input for the oil temp sensor is 3/4 NPT, my oil temp sensor is a fairly common 6-AN size fitting. I have not found any female 6-AN to 3/4 NPT male reducers. Is there a more elegant solution than just combining several reducers?
www.partskeeper.com
06-12-2013, 11:27 AM
Stolen Avitar
GA
06-20-2013, 02:57 PM
MD
It had been so long since I removed the engine from the car and changed the pan, I forgot that there was an adapter for the sensor, which was still on the Canton pan I removed. Funny enough, it was a perfect fit from 6an to 1/2 NPT......problem solved.
www.partskeeper.com
06-24-2013, 08:08 AM
Ut
Glad you got everything fixed
06-24-2013, 08:12 AM
MD
Very nice pan and so far so good on leaks!
www.partskeeper.com
11-19-2016, 12:01 AM
AZ
I may have missed it in this thread. Anybody know the ground clearance for this pan on a Kirkham. Just wondering how low it sits.
PRIDEnJOY
11-19-2016, 10:43 AM
Full Blown Member
The billet pans sit above the rails so no issues.
rodneym
11-19-2016, 02:22 PM
AZ
Thanks. I figured it was done right.
PRIDEnJOY
