January 2025
26 27 28 29 30 31
Old 10-11-2003, 12:02 PM
Default Floor Jack Lifting
What is the suggested Floor Jack lift; Side to side or front to back. The front end is a no brainer. I bought an AC Jack and it can slide under the rear past the gas tank, but not sure of a pickup point in the IRS area.
Thanks
Gary
Old 10-11-2003, 01:02 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Gary,
As you say, "The front is a no-brainer." However, the back is a bit of a challenge. It's a bit tight under the tank, particuarly for operating the jack handle. This also applies to going under the side pipe in front of the rear wheel. To solve this problem I keep four 8-inch long sections of 2X8's to drive up on, making enough room to roll the floor jack under the side pipes. Then, with a soft pad, I catch the crossmember supporting the pinion nose and up we go.
Note: I get the front up and supported with jack stands before raising the rear.
You know what? A drive-on lift works best of all! All it takes is a little more $$$$$ and room. http://www.clubcobra.com/photopost/s...t=1&thecat=500
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 10-11-2003, 04:26 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
I usually go off of the 1/8" steel channel crossmember that has 3 holes in it. Maybe thats wrong, but I have yet to have a problem.
kris kincaid
