April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 02-14-2005, 11:43 AM
Cobra Make, Engine: 66 Mustang FRPP 347ci 450 HP
Default "Swift Method" Polishing
Has anyone ever used the "Swift Method" to polish aluminum. I helped polish a Confederate Airforce plane using this method. I found the air powered Cyclo polisher we used not too hard to use. It was still alot of work!
Swift Polishing Link
Old 02-14-2005, 01:48 PM
Brent Mills's Avatar
Administrator
FlakMan, my intension has been to follow the swift method and I have the polisher and the nuvite compounds. That said, with my current project, I belive it will be for final polishing only. The body from Kirkham has been filed and sanded, so the swift method will come after I have fully sanded smooth and course buff/polished the car. At that point the swift method should work nicely for final finish (I'll let you know over the next month or two how that works out).
It's a heck of a lot of work to sand the body from 220 to 800-1200 then it only slightly gets easier. What I found is that after using a random orbital sander that it leaves a lot of little marks in the metal and they don't tend to expose themselves until you're at a really fine grit paper or you've started polishing, so you'll spend a lot of time chasing the little defects. After you get done sanding for the 10th time , taking a regular buffing pad to the project didn't seem to move enough metal to get rid of the very small blemishes, so I switched to a high speed grinder with an 8" sisal wheel and appropriate compounds to really blend and pull out the shine (careful to move quickly with a high speed unit as you'll generate heat really fast). All the sanding and the sisal wheel is getting me to the point where I think the swift method will come in to play. In other words, there is a tremendous amount of work to get to the point where it's useful and there's a lot of work left for final finish (the swift method).
Old 02-14-2005, 02:33 PM
The P51 Mustang we polished - hurt your eyes in the sun. Hope your fine machine has as much impact as that project did!
Old 04-28-2005, 06:15 PM
David Kirkham's Avatar
Original Shelby Owner
Brent,
Your car is way cool? I am about to polish my new car and I could sure use any ideas you guys have come up with to make it easier.
David
