January 2025
26 27 28 29 30 31
Old 05-15-2005, 01:50 PM
Brent Mills's Avatar
Administrator
Default Diff oil change questions on Kirkham.
Planning to do the road trip from Seattle to Reno for the WCCB next week and changing the fluids for the ride.
What oil do the Kirkhams use when they come from them and are any additives required? I would like to repeat whatever is done from their shop as it functions perfectly well to this point.
How much do I need?
Thanks for the help.
Old 05-15-2005, 05:39 PM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Brent:
I use regular Castrol 80-90 in my Kirkham and one bottle of Motorcraft Friction Modifier, available from Ford. Premix the Modifier in a bottle of gear oil and fill to the top of the filler hole.
I have an older car with their early aluminum Salisbury type pumpkin...they may have an updated recommendation.
Bud
Old 05-15-2005, 11:44 PM
Cobra Make, Engine: owned Kirkham for 11 years
Hi Brent,
Kirkham told me to fill #318 aluminium center section with 5 pints of fluid and one half pint modifier.
This amount is instead of using the fill hole as a gauge.
Maurice Lawrence
Old 05-16-2005, 08:41 AM
Cobra Make, Engine: Kirkham #259
Maurice19
Are you sure about the 5 pints???? in the Rear end????
Morris
Morris
Old 05-16-2005, 04:31 PM
Morris,
After your correction, I looked at my notes in daylight.
I should have said 3 pints lube and one half pint modifier.
54 oz total..
Thanks
Maurice
