April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 07-24-2005, 05:26 PM
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default which distributor for my southern 427?
I'm getting very frustrated with the timing issues I've had using the MSD 6AL box and the distributor (old Ford Duraspark) that Southern sent me. I'm gonna try replacing the stator, but should that fail, which distributor should I get? I've resisted to this point, pun intended, so I could maintain the stock appearance. I'd give up apprerance at this point, 'cause it doesn't look good just sitting there! Which MSD should I get? Anyone ever use a Crane distributor with the 6AL? How 'about vacuum advance? I'm not running one now. Thanx steve
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 07-24-2005, 06:22 PM
Steve,
I'm running and had been for some time the MSD pro-billet distributer/mechanical advance - I'd have no reason to ever change unless I went to a crank fired ignition. I'm sure you would be pleased and the vast majority of FE owners use them. Best wishes and sorry you've had some many issues with your engine.
Old 07-24-2005, 06:50 PM
Club Cobra Member
thanx so much for your prompt reply. Do you mean the #8594 or #8595? BTW, if I remember correctly, you'd advised me to check my needle/seats and floats...done today. reset the floats a bit, and thankfully, the needle/seats were fine. thanx again. steve
steve meltzer
Old 07-24-2005, 07:15 PM
Mine is 8594 - I didn't suggest those changes but I did chime in regarding the stator - it was a joke quite frankly based on another Southern distributor in which all the problems lead back to simply "the stator" . It was the running joke response for some time regarding any problem in which the diagnosis wasn't obvious.
Old 07-24-2005, 07:39 PM
Cobra Make, Engine: CSX4000, 427
Default Re: which distributor for my southern 427?
Originally posted by steve meltzer
which distributor for my southern -----
probably any distributor except for the light diode ones, i.e. unilite, as the diodes can burn out and leave you stranded. Probably go with a magnetically triggered one.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 07-24-2005, 08:31 PM
pgermond's Avatar
I replaced my SA distributor with an MSD Pro-Billet (8594), and also replaced the 8mm wires with 8.5mm (black). I hadn't anticipated the huge perfomance improvement (reponse). It was $$$ well spent. Look it up on Summit.... about $250 for the distributor and $75 for the wires (they don't come pre-made in black).
Good luck.
Phil
http://www.uniquecobra.com/
