December 2025
Old 11-29-2006, 06:54 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Voice of experience on alignment specs
I have the specs from Kirkham less the caster setting. Two questions: One what is the caster setting? Two, what recommendations based on personal experience would you make as the Kirkham info is a range rather than a number? Can't wait to drive the machine.
Old 11-29-2006, 09:23 AM
xlr8or's Avatar
The spec's published by Kirkham call out 4 degrees. I have mine about 3.5
Ride Height, Front 4.5"
¾" less than rear
Ride Height, Rear
5.25"
¾" more than front
Caster
Camber, Front
-½°
Camber, Rear
-½°
Toe, Front
1/8" toe in
Toe, Rear
1/8" toe in
Old 11-29-2006, 10:30 AM
Murphy's Avatar
Thanks. All I need now is a license plate and title.
