March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree2Likes
  #201 (permalink)
Old 08-25-2007, 02:00 PM
David Kirkham's Avatar
Original Shelby Owner
TRANSMISSION INSTALLATION:
Gents, here are a few things you need to make sure of to finish up your transmission installation.
Pull this plug out of your transmission! If you forget, you will have a GIGABYTE of tranny oil on your floor. This plug is for the installation of the mechanical speedo cable. But, since we do not use the mechanical speedo (we have the cool new electronic gauges) we will need to put a more permanent plug in this hole.
  #202 (permalink)
Old 08-25-2007, 02:03 PM
Here is a picture of a cool little billet plug we make--complete with an o-ring so it no leaky, leaky. (Remember to oil the o-ring so it slips in and doesn't get cut on the way in.) If you cut the o-ring, you will have leaky, leaky.
  #203 (permalink)
Old 08-25-2007, 02:05 PM
Just take the plug and stick it in the hole. Take the big fender washer we supply you with, along with the 1/4-20 x 1/2 bolt and bolt the baby down so it doesn't fall out at some unopportune moment. (Like when a tech inspector is watching!)
  #204 (permalink)
Old 08-25-2007, 02:07 PM
This is where our speedo "plugs in."
  #205 (permalink)
Old 08-25-2007, 02:09 PM
This is the neutral safety switch wiring. It is not used in our car (or original 427 Cobras).
  #206 (permalink)
Old 08-25-2007, 02:10 PM
We simply tuck it the wires back by the mount.
  #207 (permalink)
Old 08-25-2007, 02:15 PM
Here is a sneak peak of our latest cool part to come off our CNC machines. We water jet the flanges out of 5/16" 304 inch stainless. The tubes are 304 stainless as well. If you notice, the head tubes are all ONE piece! We made special tooling here in house to get the bends as tight as possible. There is NO welding on the head tubes (except for the flanges to the tube, of course). No welds means the head tubes will never fatigue and crack at a head tube joint because there aren't any. Our headers are patterned after Dave Dralle's original
CSX3020. The head tubes merge together at a collector outside of the car.
The head tubes shown here have the extra polished option. Sandwich is the master CNC tube bender programming wizard.
  #208 (permalink)
Old 08-25-2007, 06:56 PM
computerworks's Avatar
To keep the continuity of this thread, PLEASE post all comments and questions on the Assembly Manual Questions Thread
  #209 (permalink)
Old 10-25-2007, 09:42 AM
Default Brazilian Cobra Project
David,
Thanks for all your help.
I am almost finalizing my project. We manage to put the entire car together and now I just have send it to Sid Mosca (http://www.sidmosca.com.br/) the guy who is famous for painting F1 helmets for Sena, Piquet, Fitipaldi and others.
It should stay there for at least more 3 weeks, after that, the car will go for a person that will do its electrical job and then to the guy that will put the carpet on the car.
As soon as it is ready I will send you pictures.
Yours sincerely,
Eduardo Prada
  #210 (permalink)
Old 04-12-2010, 05:44 PM
FUNFER2's Avatar
You Kirkhams NEVER,...... cease to amaze me !
Along with all the other parts you make, the headers are truly a work of art. Even such a small piece like the transmission plug.
I'd love to work with your team free,.... for a year, just to learn fabrication from the best.
Regards,
Kevin
  #211 (permalink)
Old 04-12-2010, 06:43 PM
FUNFER2's Avatar
David- I just received a SFI rated steel bellhousing from "QuickTime". You don't need to do any modifications as with the Lakewood. I haven't installed it yet and I'll report when finished.
http://www.quicktimeinc.com/products.html
RM-6056 - FE Big Block Ford Bellhousing to Ford TKO 500-600/T5 Mustang/TR3550 transmission
RM-6056-SFI FORD 352/390/427/428 BB TO T5/TKO BELLHOUSING S F I 6 . 1 $ 565.73
Height = 7.050"
Trans. Bore Ø = Universal 4.850/4.910
Engine = Ford 352/390/427/428
Trans. = Universal Ford TKO 500-600/T5 Mustang/TR3550
Clutch Ø = 12"
Flywheel = 184 tooth
Weight = 22#
Universal shifter fork brackets for diaphragm or cable operated linkage
Has passed ALL SFI testing
Pivot ball, fork brackets, FULL engine plate and grade 8 bolts included.
FE TO TREMEC-
Regards,
Kevin
  #212 (permalink)
Old 09-20-2010, 03:17 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Will this Manual continue to be updated?
Great work so far and very helpful!
  #213 (permalink)
Old 10-12-2010, 06:23 PM
ROSS WEAVER's Avatar
I just found this thread. Great info for a future purchase, thanks.
  #214 (permalink)
Old 07-02-2019, 05:34 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
I wish David would continue this thread.
  #215 (permalink)
Old 07-25-2019, 01:56 PM
With the big move and all the orders we are working on to catch up I just haven't had time. But I would like to do another build. I will definitely keep it in mind!
David
DKlee likes this.
