April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 08-27-2007, 09:45 AM
Cobra Make, Engine: Kirkham 592
Default Rear end ratios
I found a posi Jag rear for $250. I'm going to pick it up this weds. The guy thinks it's a 3:07? How would that work with a toploader? Anybody running one? How hard are the gears to change?
Old 08-27-2007, 10:49 AM
Badsnake427's Avatar
Cobra Make, Engine: Classic Roadster SC
http://www.secondstrike.com/Technical/GearCalc.asp
Old 08-27-2007, 03:51 PM
ZOERA-SC7XX's Avatar
Make sure it's what you want...many Jag (XJS) posi's are in fact 2:88's. If it's from an XJ6 or XJ12 you may be in business. To check, just turn the axle one complete turn and count the # of rotations of the pinion. Good luck. Also, it's worthwhile to rebuild the entire center section.
Old 08-27-2007, 04:25 PM
ENTDOC's Avatar
number one, make sure it is from the proper year, the later ones have big bolts protruding from the top for mounting and an aluminum rear cover, the proper ones have a flat top surface. 3.07, I think would be perfect for a toploader. The highway RPM's would be better and low end will suffer only mildly and be more controllable. I have 3.31 and would go to a higher ratio if I did it again.
Old 08-27-2007, 05:45 PM
Which year is recomende? Any pics of what the correct year looks like?
Thanks
chris
Old 08-27-2007, 06:07 PM
ENTDOC's Avatar
you want the one at the top of the pic not the bottom one
Old 08-27-2007, 06:23 PM
joey_hv's Avatar
Cobra Make, Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
does anyone know who can work on these? i have one that needs to be freshened up.
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Old 08-27-2007, 06:35 PM
Try these people. I'm sure there are others.
http://www.cwiinc.com/
Old 08-27-2007, 06:46 PM
joey_hv's Avatar
thanks, i'll get in touch with them
Old 08-28-2007, 02:05 PM
I used Curt Hamilton (Hamilton Automotive Ind., Van Nuys, Ca. 818 787 9695), whos reference came from right here on Club Cobra. Very reputable and reasonable.
Old 08-28-2007, 05:01 PM
joey_hv's Avatar
i'll check on them too, thanks!
Old 08-28-2007, 05:38 PM
CHANMADD's Avatar
I ran a 3.07 open diff for a long time,and recently changed to a posi 2.88.I like the difference a lot for the street,slightly more relaxed freeway cruising and to be honest 60+mph in first is great.Some of the jag center sections have a round pinion input flange,This is a Salisbury. Some have a rectangle ,like a Chevy which bolts the UJoint with a shackle,These are Dana rear ends.This now brings the choice of Dana versus Salisbury.I like the Salisbury becouase it has flat clutch discs as apposed to the "cone "clutch in the Dana.The Dana also has holes drilled in the disc to enable you to remove the caliper,where as the Salisbury does not need these holes.
