February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 11-02-2007, 05:29 PM
RodKnock's Avatar
Default External Clutch Slave Cylinder for QT Bellhousing?
Is there an external clutch slave cylinder setup available for the Quicktime bellhousing yet? I thought maybe the Kirkhams might be working on one. Thank you.
Old 11-02-2007, 06:06 PM
Hi Rod,
The external slave kit for the Quick Time and Lakewood bellhousings I sell and install. I designed this billet aluminum fork, external slave kit. The kit sells for $300.00.
I also designed one that uses an OEM style fork to be used with a 1 3/8" Top Loader for $325.00 or another unit that fits the 1 1/16" Top Loader for $275.00
Mike Forte
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 11-02-2007, 07:50 PM
xracerbob's Avatar
Cobra Make, Engine: ERA 758 KC Pond 482
I think ERA has one. They mention the QT bellhousing as an option on the website. I forgot to ask them about it when I was there.
Old 11-02-2007, 08:24 PM
RodKnock's Avatar
Hi Mike,
Will your QT setup work with a TKO600? Again, thank you.
Old 11-02-2007, 08:35 PM
Hi,
I have many versions for the FE, 429/460 & SB Ford (GM, AMC & Mopar too).
I have Quick Time bellhousings in both TKO-600 or TKO-500 with the stock input. I then have Quick Time bellhousings that will mount a Top Loader length input.
I also sell a Lakewood with a spacer plate for the TKO-600, I install short input shafts into either the TKO-600 & TKO-500.
Forte's (that's me) developed the GM & Early Ford TKO & 3550 from a stock Tremec 3550 & TKO. I also developed the firewall adjustable quadrant kit for the Mustang and the external billet fork & slave kit for most aftermarket bellhousings.
40 Pearl St
fortesparts.com
508 875 0016
Old 11-02-2007, 08:43 PM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
I talked to KMP a couple of weeks ago and at that time they were still in the very early stages developing a clutch setup for the QT bellhousing.
I just did a preliminary dial in on my QT bellhousing and am going to install the hydraulic TOB for use with the Tremec 600.
I did not want to send off my new BH to be worked on, wanted to do it myself. I am working with a company called The Driven Man for components, a one man company but really on top of it with great service.
Old 11-03-2007, 12:34 AM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Can you use a stock fork and a Wilwood external slave? Summit sells the slave for about $60 as I recall. Very easy to mount and set up.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 11-03-2007, 12:57 AM
Hi,
The Wilwood slave is very prone to failure at the O-rings that seal the hydraulic oil. It is an easier fix than the hydraulic throw out bearing. when it fails you must remove the transmission (where it happens) and try to repair it with a repair kit. VERY EXPENSIVE to fix.... if you can!!!!
40 Pearl St
fortesparts.com
508 875 0016
Old 11-03-2007, 01:22 AM
427sharpe's Avatar
Wrong style in question...
The Wilwood slave I used is pictured below. Used -4 line and a heim joint to mount the slave to the trans crossmember (it is a 'pull' type). Drilled one 5/16 hole in the oe fork and mount her up. No need to remove trans IF it leaks, and so far it has been a-ok.
Old 11-03-2007, 02:09 AM
xlr8or's Avatar
Rodney,
I just got the QT housing and external slave from Mike. Very nice piece of work. Great service from Mike as well.
When I called Kirkham they didn't have one available for the QT housing yet, just the Lakewood. The QT bellhousing is real nice, half the weight and didn't require any trimming to fit in the frame or for ground clearance.
Scott
Old 11-03-2007, 01:51 PM
RodKnock's Avatar
Scott,
Plagiarism is the sincerest form of flattery. I hope you don't mind, but I'm trying to copy you by getting the QT bellhousing, but I wasn't aware that someone makes the external slave cylinder for it yet. However, now I know. I plan to call Mike Forte on Monday and order the entire setup. Thank you.
Old 11-04-2007, 10:43 AM
Hi Rod,
I have the FE flywheel in both 0-balance & ext balance for a 428, matching Ram diaphram clutch components (I also have release kits for the FORD Long style), bellhousing and external slave & billet for I developed.
40 Pearl St
fortesparts.com
508 875 0016
Old 11-04-2007, 11:31 AM
Blittleton's Avatar
CC Member / Sponsor
Rodknock,
I came up with an external bracket and slave cylinder for a quick bellhousing. I mainly use it for a 351 based motors but it shouldn't matter if a using a big block, as long as you are using a tremec transmission.. such as a TKO 500 or 600. If you are interested give me a call at 859-630-9099.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 11-04-2007, 11:43 AM
767Jockey's Avatar
Bill,
Will your setup work for a Cleveland? What slave do you use, and what's the cost for the whole setup?
Old 11-04-2007, 01:39 PM
Hi,
I spoke with someone earlier with a 1 3/8" Toploader. With that I use a modified stock fork, throwout bearing & billet slave & bracket. This applies to FE, 429-460 & SB Ford with the big input including Clevelands.
All other clutches are diaphram and will work on all the above Ford engines. These are all tried & proven.
40 Pearl St
fortesparts.com
508 875 0016
Old 11-04-2007, 02:24 PM
767Jockey's Avatar
Mike,
What's your setup for a Cleveland with a 10 1/2" flywheel and a TKO 600?
Old 11-04-2007, 07:10 PM
Hi 767,
The external kit on a new McLeod blowshiels is $675.00. On a Quick Time is $675.00 or $50.00 more for the SFI approved model.
Mike
40 Pearl St
fortesparts.com
508 875 0016
Old 11-04-2007, 08:27 PM
Blittleton's Avatar
CC Member / Sponsor
It will fit if you are using a quick time bellhousing with a TKO-500 or 600. I can supply the bracket and the slave cylinder. $75.00 + shipping.
Bill
www.gcperf.com
Old 11-05-2007, 05:57 AM
Blittleton's Avatar
CC Member / Sponsor
Sorry Mike, I didn't mean to just on your post. I like your setups.'
Bill
www.gcperf.com
Old 11-05-2007, 05:55 PM
RodKnock's Avatar
The Kirkhams have just developed their setup where a hole is drilled into the QT bellhousing and the opening is trimmed. No welding required. Mike Forte's design welds a mount to the QT bellhousing for the slave cylinder. Would anyone have any info on which setup is better/stronger setting aside cost...for the moment. Thank you.
