March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree2Likes
  #661 (permalink)
Old 07-10-2008, 08:28 PM
saltytri's Avatar
Cobra Make, Engine: KMP, Keith Craft
Originally Posted by David Kirkham View Post
I think I have risen as far as I can go...that is, unless I eat another burrito.
David
Go ahead, have TWO more burritos. You've earned them for Meritorious Sweeping Service.
  #662 (permalink)
Old 07-10-2008, 08:55 PM
David Kirkham's Avatar
Original Shelby Owner
The only thing two would earn me is the sofa.
David
  #663 (permalink)
Old 07-10-2008, 09:51 PM
Cobra Make, Engine: ERA 381, 427 Side Oiler
[quote=David Kirkham;860027]Ask and ye shall receive.
I just told Joe to go and film the Janitor.
I throughly enjoyed all 84 seconds of that clip, twice.
  #664 (permalink)
Old 07-11-2008, 06:45 AM
Anything else you would like to see?
(We will do a running shot of the car once the body is on).
David
  #665 (permalink)
Old 07-11-2008, 08:24 AM
saltytri's Avatar
How 'bout a clip of Mom chewing you out for screwing something up?
  #666 (permalink)
Old 07-11-2008, 08:52 AM
That's all I'd post if I did that...
I'm really bad at following directions. Just ask Jamo.
David
  #667 (permalink)
Old 07-11-2008, 09:50 AM
Here is a video of us fitting the front cockpit tube to the body. Most people don't realize how extremely difficult it is to mount an aluminum body. I try to explain it to people that mounting the body is actually much harder than taking a flat sheet of aluminum and turning it into the body in the first place.
Here I will go through the steps of fitting a body to a chassis for the first time. After the first time, it is a lot easier (but still extremely difficult) to mount the body. The first time you have to pay very close attention to the 3D nature of the body and make sure you mount it on correctly AND STRAIGHT! I have seen a LOT of exceptionally poor aluminum body mounting jobs. I have seen exquisite workmanship literally destroyed by people who thought they knew what they were doing.
  #668 (permalink)
Old 07-11-2008, 11:57 AM
Here we are actually mounting the body onto the chassis. It is not permanent, but we are getting there. We rivet (or cleco) the body on once we get the measurements correct because clamps can slip...
Then, I promise, you will have a very bad day.
  #669 (permalink)
Old 07-11-2008, 08:00 PM
Here is our CNC tube bender with the simulation page opened up. We simulate the bends before we bend them. That helps to keep the scrap pile to a minimum. The simulation is not perfect, but it sure helps.
  #670 (permalink)
Old 07-11-2008, 08:01 PM
And another screen shot of the CNC tube bending simulation.
  #671 (permalink)
Old 07-11-2008, 08:18 PM
Notice the really clean, tight fit on the tube.
  #672 (permalink)
Old 07-11-2008, 08:19 PM
That tube fits so well it is held on entirely by friction.
  #673 (permalink)
Old 07-11-2008, 09:21 PM
Here we are contemplating how to mount the front clip.
  #674 (permalink)
Old 07-11-2008, 09:23 PM
We started by welding in the tube here right above the radiator. The first tube is critical to the overall orientation of the body. Mounting a body is an extremely difficult proposition. Many, many people have ruined otherwise wonderful bodies by not knowing how to mount them. Mounting a body is a 3D problem. Most people don't think in 3 dimensions and so the body ends up off in one of the dimensions. It takes a long time and a lot of measuring to get everything lined up correctly.
  #675 (permalink)
Old 07-11-2008, 09:27 PM
We had a tremendous advantage in the fact our chassis was already perfectly symmetrical from the wonderful CAD data we had. When you weld an original chassis together, it moves all over the place and it drives you crazy. So, the sub structure is no longer straight--even if you were careful and measured everything CORRECTLY. Welding warps things. Like I say, we were very lucky to have a symmetrical and orthogonal chassis to start with. It made mounting the body much, much easier.
  #676 (permalink)
Old 07-12-2008, 09:15 AM
Here we are trimming the rear body clip to fit.
  #677 (permalink)
Old 07-12-2008, 09:47 AM
The first thing we did was take the CAD data and measure the leading edge tube for the hood and position it exactly in all 3 dimensions to make sure it was in the right place. Then, we tacked the tube in place.
  #678 (permalink)
Old 07-12-2008, 09:49 AM
Then we trial fit the front body clip.
  #679 (permalink)
Old 07-12-2008, 09:57 AM
  #680 (permalink)
Old 07-12-2008, 10:09 AM
Here we are lowering the body into place.
