questions
- » Blogs
- » Image Gallery
million posts!
March 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
2Likes
07-12-2008, 10:11 AM
Ut
Once we were happy with the fit, we took the front cockpit tube, bent it to shape and then cleco'd it to the body. (That's the cleco you see sticking out here.) Then, we took a little tube and fit it to the cowl tube. We then lowered the body down onto the little tube, measured everything, and then...
Advertising
07-12-2008, 10:15 AM
Ut
Then you tack weld everything into place. Tack weld means very small weld--so it isn't so hard to break when you have to reposition the tubes because you measured wrong...
07-12-2008, 10:44 AM
Ut
Here is a close up of the center cockpit support tube. Notice how it is already perfectly notched courtesy of our mill.
07-12-2008, 11:23 AM
NJ
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
David and Tom,
I think now that you guys have mastered all in your fiefdom...itc time to consider producing the Flip Top Cobra (The Turd).
.....that would be amazing!
REMEMBER....In Case of Spin....Both Feet in!!!!!
07-12-2008, 11:36 AM
Ut
07-12-2008, 11:39 AM
Ut
Originally Posted by John McMahon
David and Tom,
Perhaps our fiefdom lies outside familiar pastures.
David
07-12-2008, 03:46 PM
Ut
You have to check, check, check to make sure things are right and square.
07-12-2008, 03:47 PM
Ut
Here we are checking the "Z" axis height of the body relative to our CAD drawing. It is right on the money.
07-12-2008, 03:49 PM
Ut
Here is the tool we used to measure with. You see Sandwich using it in the previous picture. Because we had to measure around the radiator to our datum, we sheared a piece of aluminum exactly at 11.4 inches long. We made sure the edges were perfectly square then we could measure over to the body.
07-12-2008, 03:52 PM
Ut
When we are very sure everything is perfectly square--we weld again.
07-12-2008, 04:22 PM
Ut
We write all the measurements down on the car so they can't get lost or walk away. Everyone knows what the measurements are and everyone knows we expect things to be as perfect as possible.
07-12-2008, 04:46 PM
Ut
More notes on the CAD dimensions.
07-12-2008, 04:58 PM
Ut
07-12-2008, 05:57 PM
Ut
07-12-2008, 06:50 PM
Super Moderator
CA
Originally Posted by David Kirkham
That's all I'd post if I did that...
I'm really bad at following directions. Just ask Jamo.
David
Oh, the tales I could tell...
Jamo
07-12-2008, 09:08 PM
CA
Cobra Make, Engine: KMP 498
Great work.
The real question is this: Is David (Dr. Billet) & Company-- reinventing a simple Cobra Kit car or are they creating one of the finest pieces of art I have ever seen? (Yes, I have seen alot) It is almost a shame to put a body on it!
Sanded Aluminum Finish? Because I Can!
07-13-2008, 03:30 PM
Ut
OK, how much to keep you quiet...
David
07-13-2008, 03:32 PM
Ut
Originally Posted by big-boss
Great work.
The project is planned as a one-off. I think it would be prohibitively expensive to sell these as a "normal" kit.
Everyone who sees the car says it is a shame to put a body on it. I need to think of a way to make the body easily removable. Now, that will be a trick that will probably not be possible. But, as you can see, I love a challenge.
David
07-13-2008, 03:33 PM
Ut
07-13-2008, 03:35 PM
Ut
Here are a few more pics of the ride coming along.
