January 2025
26 27 28 29 30 31
  #41 (permalink)
Old 01-10-2009, 04:29 PM
David Kirkham's Avatar
Original Shelby Owner
More importantly, has the price come down.
Are the first ten spoken for?
We have held off on it as the billet car sucked all the life out of us. Now that it is delivered, we can focus on other projects.
David
  #42 (permalink)
Old 01-12-2009, 12:07 AM
Cobra Make, Engine: Kirkham, 482 Shelby / TKO 600
Any specials on the external clutch actuator / bellhousing?
  #43 (permalink)
Old 01-12-2009, 10:07 AM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Speaking of the billet car......
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
  #44 (permalink)
Old 01-12-2009, 12:45 PM
They are $395 retail.
We will sell the next 5 of them for $300
This CC member special is good 5 units only. When 5 are sold (or two weeks maximum time passes by) the sale is OVER!
Starting NOW!
Our external unit works Tremec transmissions:
Small block with Lakewood bell housing
Small block with McLeod bell housing
FE with Lakewood bell housing
FE with McLeod bell housing
Let me know what you have.
David
  #45 (permalink)
Old 01-12-2009, 12:47 PM
Getting there. I am writing a book on the car. I just passed 1000 pages...no, that is not a type. I am going to have to cut back a bit I can see.
David
  #46 (permalink)
Old 01-12-2009, 01:02 PM
RodKnock's Avatar
Starting NOW!
David
I can attest to the craftsmanship and it works beautifully. The Kirkhams also modified my QT bellhousing for me to use with their setup. Very nice.
  #47 (permalink)
Old 01-12-2009, 02:23 PM
David,
Can you supply the modified QT Bellhousing for the clutch set up? I assume all of the bolts from the bellhousing to block are still used? I saw another set up and the slave mounting bracket did not allow access to one of the bellhousing bolts. Sorry for all the questions, I just want to make sure that I know what I am buying. I search for a picture but could not find one, do you know where I can see the set up?
Do you recommend the QT bellhousing or a different one?
Thanks,
Peter
  #48 (permalink)
Old 01-12-2009, 02:31 PM
RodKnock's Avatar
Just shoot an email or call QT and they will answer your question. I would buy one from one of the supporting sponsors and have them ship it to UT.
The QT bellhousing is far lighter and smaller in size. I would highly recommend it.
  #49 (permalink)
Old 01-12-2009, 02:53 PM
David,
Thanks,
Peter
Peter,
What motor? FE or Small block? I'll post pics.
We like the Quick Time bell housing. They are much lighter than the Lakewood.
Yes, we can supply the bell housing. We charge $100 to modify it. The clutch fork opening has to be slightly enlarged. Then, we cut the bottom flange off so it won't catch on road kill.
David
  #50 (permalink)
Old 01-12-2009, 04:53 PM
Davis,
I have a Shelby block 482 and a TKO 600. Do you recommend the Quick Time RM 6056 or RM 6056 SFI? Have you seen the 6056 SFI with the lower cover ? Please post a picture of the clutch slave and I will call you to order.
Thanks,
peter
  #51 (permalink)
Old 01-12-2009, 05:16 PM
philminotti's Avatar
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Peter, you have an email.
phil
  #52 (permalink)
Old 01-12-2009, 05:29 PM
RodKnock's Avatar
If you plan to track the car, then SFI.
  #53 (permalink)
Old 01-12-2009, 06:08 PM
Davis,
Thanks,
peter
Here is a link with more info that you probably want to know!
http://clubcobra.com/forums/showthre...t=80230&page=5
  #54 (permalink)
Old 01-12-2009, 06:09 PM
Lets see if this works
  #55 (permalink)
Old 01-12-2009, 06:16 PM
The Quick Time bell housing is a little different, but pretty close. I don't have a photo of the QT that I can find right now.
David
  #56 (permalink)
Old 01-12-2009, 06:49 PM
Cobra Make, Engine: Kirkham #570 w Shelby FE
I'll take a pic of mine, since it's sitting in the garage.
The mods not too hard, have to take about 3/4" off the top edge of the opening and drill a 1/2" hole in the flange for the pivot bolt.
I marked off the cut and drilled two 3/8" holes at each corner, then made the cuts with a cut-off wheel in my die grinder. Took about an hour. (triple checking measurements since I didn't want to mess up)
Haven't lopped off the bottom, yet.
  #57 (permalink)
Old 01-12-2009, 07:05 PM
Ronbo,
I'd chop the bottom...BEFORE something else does it for you!
David
  #58 (permalink)
Old 01-12-2009, 08:28 PM
Cobra Make, Engine: Superformance SPO1597
Default Cold Air Box
David,
Any plans on producing a cold air box for a 351W?
Thanks,
Ed Dowey
  #59 (permalink)
Old 01-12-2009, 08:34 PM
Originally Posted by edowey View Post
David,
Thanks,
Ed Dowey
Can do...no problem.
How much room do you 351 guys have between the carb studs and the distributor?
Anyone want to volunteer to be a guinea pig? We'll draw it up tomorrow.
$50 off to the 1st guinea pig. That's $200 (already discounted) less $50 for $150. 1st guy with the measurement ONLY!
David
  #60 (permalink)
Old 01-12-2009, 09:20 PM
Default 351 W Guy
David.
I took a quick measurement on mine and I have 3.5 inches middle of front carb stud to back of distributor. This is a loose measurement which will leave a little finger room. I'm in for $150.
Ed Dowey
