questions
- » Blogs
- » Image Gallery
million posts!
January 2025
1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
02-17-2009, 04:23 AM
UK
Cobra Make, Engine: Kirkham #523, 427 S/O
Should my engine be central?
Hi,
I've just taken the hood scoop off my Kirkham in preparation for rubbing down the bodywork and I noticed that the air filter isn't central to the hole in the hood.
I wasn't sure whether the carb was positioned centrally on the engine, so I thought I'd check the bottom of the engine. I have a Canton oil pan and the gap between the chassis rails and the oil pan wings is different from one side to the other by about 3/4" (the drivers side gap is larger).
This also obviously effects the side-pipes. The drivers side-pipe runs close the the body, whereas the passenger side-pipe is some distance off. I had just put this down to tolerances in the pipe bending, but maybe it isn't.
The engine doesn't seem to want to sit anywhere other than where it is. Am I missing something?
Your thoughts would be appreciated.
Thanks,
Paul
Advertising
02-17-2009, 05:46 AM
NV
Cobra Make, Engine: 427 SC
The chassis was designed to offset the engine 1/2" towards the right side. Thats the way it's supposed to be.
02-17-2009, 05:58 AM
UK
Thanks Kris.
I was puzzled about how I was going to correct it if it was wrong, but I'm now reassured that all is as it should be.
Thanks again.
Paul
02-17-2009, 06:22 AM
NH
It helps align transmission and pinion(the pinion is offset), gives a little more footroom on the pedal side and balances the car side to side with the one person who has a roll bar.
02-17-2009, 08:45 AM
UK
Having checked the measurements, it is exactly ½" off centre, so you were right on the button Kris.
02-17-2009, 09:05 AM
WI
Cobra Make, Engine: B+B 351w #112
Wasn't it because of the sidewinder intake used on the big blocks? Carb doesn't sit in the middle of the engine. Jim
02-17-2009, 09:28 AM
UK
That had crossed my mind, which is why I also checked the bottom of the engine and found that the block was off-centre by the same amount as the carb.
Therefore, I'm happy with Kris and Mickmate's responses.
Paul
02-17-2009, 12:05 PM
CC Member / Sponsor
UT
The small block cars are also offset. This was to reduce the angle on the drive shaft.
02-24-2009, 07:22 PM
vic
Cobra Make, Engine: 1965 registered Brushed Kirkham polished stripes, 427 FE kieth craft 482 efi.ss chassis and all the go gear .
Bloody good question, i thought it was just my car #385 in Australia.
" And them boys in them Chevy's,are going to say Pipes!!! Look at them pipes !!!- Bill Cosby 200MPH.
02-27-2009, 04:08 PM
Ut
The pinion on the differential is 1.000 inches offset to the right of the car. To keep the drive line angles reasonable, the engine is 1/2" offset to the right of the car. Of course, this makes for some very interesting issues when you are dealing with a right hand drive car!
The 1/2 inch offset is original.
David
