Like Tree1Likes
Old 06-15-2009, 01:57 AM
PANAVIA's Avatar
Default FE Motor Mounts -
What is the favorite Brand and $ of the FE motor mounts for the Kirkham 427s with the FE motor>?
--Steve
Old 06-15-2009, 10:48 AM
FatBoy's Avatar
Kirkham produce their own mounts, which I suspect is what the majority of owners use.
Paul
Old 06-15-2009, 12:53 PM
Cobra Make, Engine: KMP 498
I have the KMS ones, only way to go.
Sanded Aluminum Finish? Because I Can!
Old 07-29-2009, 03:41 PM
FUNFER2's Avatar
I'm interested too. Is the KMP solid or rubberized/other ?
How well is the vibration control ?
Any pics & price ?
Kevin
Old 07-29-2009, 04:43 PM
Cobra Make, Engine: Kirkham 592
They are a beautiful piece. Look under the build thread on page 13 or 14 there are some pics of them
Chris
Old 07-29-2009, 05:09 PM
David Kirkham's Avatar
Original Shelby Owner
Our billet FE motor mounts are $295. (They come with the purchase of a roller.)
We make them in 2 pieces which makes it much easier to install the motor. Just line up the bolts in the holes and drop in the motor. They are also designed so they can not "break" and have the motor torque over and slam the side pipes into the body...no fun on the original cars. We have a cross bolt going all the way through them to prevent such mishaps.
We use urethane bushings to keep the vibrations down.
Old 07-29-2009, 08:20 PM
FUNFER2's Avatar
David, I sure would appreciate a photo.
Thanks.
Kevin
Old 07-29-2009, 08:31 PM
Thanks.
They look like this:
rodneym likes this.
Old 07-29-2009, 08:44 PM
Default ... and for something completely different
ERA runs a bolt through the motor mount, like this:
Old 07-30-2009, 06:49 AM
FUNFER2's Avatar
Very nice. How much are the ERA's ?
Kevin
Old 07-30-2009, 06:52 AM
Print the page link below and take it, along with your left motor mount, to your local machine shop and I bet they'll do it whle-u-wait for less than $25.
http://www.erareplicas.com/427man/en...tmod/index.htm
Old 07-30-2009, 07:39 AM
Default Other Options...
I've always thought these mounts from Total Control Products looked pretty cool They're $229 for the FE and a replacement bushing set is $39. http://www.totalcontrolproducts.com/motormounts.html
Old 07-30-2009, 07:59 AM
Default Engine mounts
David,
Do your mounts have the same dimension frame to top mount surface as original FE mounts? Cris from Kinetics told me that you guys mount your engines a little higher than originals, do you accomplish that at the frame cradle or the mount? You have a very well designed part that I would be interested in installing if the dimensions are identical to original mounts.
Old 04-13-2010, 09:12 PM
FUNFER2's Avatar
I'm interested too and I like the two piece design.
Kevin
Old 07-09-2010, 03:24 PM
FUNFER2's Avatar
I also have the stock mounts and will need more information on the height.
Kevin
Old 07-12-2010, 12:47 AM
PANAVIA's Avatar
The STOCK mounts for a FE cobra were they 1958-59 TBird FE mount. -- they work if you cross bolt them. The kirkham mount is an interesting upgrade and if you are in the car that far, the cost should not really be a concern.
Old 07-12-2010, 06:15 AM
FUNFER2's Avatar
cross bolt ?
Kevin
Old 07-12-2010, 05:19 PM
We drill a hole through the original style mounts so if the vulcanization come apart the motor mount will not separate.
Eventually, we just started to billet the mounts with a cross bolt designed right into the part.
Old 07-12-2010, 05:34 PM
CC Member / Sponsor
Originally Posted by PANAVIA View Post
The STOCK mounts for a FE cobra were they 1958-59 TBird FE mount...
The original part number is: C1MM-6038-C
I believe this came from a 1961 Mercury Marauder.
Note that the NAPA (Anchor, and Buffalo) replacement part does NOT have the same off set.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 07-13-2010, 03:53 PM
PANAVIA's Avatar
The Anchor product is also the victim of a short bolt to the frame as well.
there is a repro thud mount that seems to work, but it is in short supply.
if you are that far down the road, the K mount is a nice upgrade!
