Go Back   Club Cobra > Club Forums > Las Vegas Cobra Club
January 2025
26 27 28 29 30 31
Old 10-20-2011, 10:02 AM
Cobra Make, Engine: Backdraft, 408 Stroker
Default Recommendations for a stage control kit
I want to put a line lock on my car and hope that someone has installed one and could tell me if it works and how hard it is to install. I have found a 555-63002K from JEGS, but do not know if it is a good unit.
Old 10-20-2011, 11:05 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Yes they work...easy answer. No you don't need all the extra stuff they sell. All the lock is, is a solenoid. Put it in the front wheel line, some people do one wheel or two wheel lock. I didn't mine to lock both wheels. Then you will need a button to activate. Run an electric line from fuse block to line lock and then through the button. Press down on brakes, then press the button. The solenoid closes, take foot off brake. Front brakes still have pressure on them as long as you hold the button. You can get a solenoid for 30-40 dollars, another 25 dollars for parts and you're done.
Jack
XSSIVE .....
Old 10-20-2011, 12:30 PM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
I used summit part # BMM-46076- $72.95- solenoid, button that lights, fuse, everything you need except the fittings, but you should have fittings from the build.
It's really fun to use to do long smokey burnouts.
Old 10-20-2011, 12:44 PM
I have the original Hurst Line-Loc and it works very well.
However-do NOT use it without rolling in water box first<<if you have IRS>> or you will grenade the IRS. And don't clown on the street with it-you'll really hurt the car and your wallet.
Chas.
Old 10-20-2011, 12:47 PM
bobcowan's Avatar
I also used the Summit solenoid. Splicing it into the front brake lines was about as easy as it gets. Run a low amp poer line through the switch and to the solenoid, and oyu're done. Pretty simple, really.
I use mine all the time: getting started on hills, loading into the trailer, etc. Very handy.
I initaially used that shifter ball with the switch built in. Looks cool, and very easy to use, especially with the standard goofy shifter arm angle. But, it didn't last very long. I replaced that with a Hurst button that has an elastic strap for the shifter arm. That has worked excellenty for years.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
