Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Lone Star Classics---Speak with Dennis & Steve
December 2024
Old 07-04-2017, 11:02 PM
Cobra Make, Engine: Lone Star, Ford 302W
Default Bump Steer
I've been driving my Cobra for a couple months since completing it after working on it for about 5 years. Being a chassis nerd, I noticed there was a ton of bump steer in the front end, but didn't take the time to try to do anything about it because I was all wrapped up in assembling the thing and not much was mentioned about it on the Lone Star Forum, so i figured it wasn't a big deal. But the faster I drive the thing, the more it bothers me. Has anyone done anything to address this issue?
Am I correct in assuming the front end geometry is similar to a Mustang-II? I know the steering rack needs to be raised, or the steering arm pivots need to be lowered a considerable amount, and there are kits to do exactly that available for the M-II with spacers, etc. Just wondering if this is some popular "must do" thing I just didn't know about.
Old 10-17-2017, 07:42 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
The caster affects the needed elevation of the rack. If you're running more positive caster than the stock M2 alignment, you may need to raise the rack. With a little geometry you can figure out how much. I think you could easily elongate the 2 rack mounting holes and fix it that way, or reduce the caster. The positive caster gives more restorative force to center the wheel at speed, which isn't a bad thing in this short wheel based car. I think I'm only running 2 deg and have no noticeable bump steer.
Old 12-06-2018, 02:04 PM
Registered User
Cobra Make, Engine: Lone Star Classics, Ft Worth, TX
Default All Geometry is bad not just bump steer
The geometry on a Lone Star is horrible. Bump steer is the least of the issues. The LSC was designed by a street rod guy and made more like a street rod than a good handling sports car.
Cap'n Crunch
Old 12-06-2018, 03:24 PM
xb-60's Avatar
Bump steer will also cause the inner side of your front tyres to wear very quickly.
Is there a mod available for the steering knuckle to raise or lower the steering outer tie-rod to a static horizontal position?
