04-01-2013, 04:24 AM
May have a clutch problem
Wastehauler, you didnot say which clutch you are running. It's very possible that the pressure plate or disc is going south after 7,000 miles. If you have a hrdro throw out bearing, flush the system and retry. If you have a opening in the bell housing where you can get a feeler gauge between the pressure plate and disc, check the air gap. You want between .035" to .050". They fixed most of the problems with the forks in TKO boxes and you said you rechecked the linkage. This will get you started. Rick L.
