Go Back   Club Cobra > Club Forums > NorCal Cobras
April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 01-19-2010, 10:39 AM
pgermond's Avatar
Neutral
Question Radiator Shop
Any recommendations on a good radiator shop in the Sacramento/Roseville area? My aluminum radiator has a leak that appears to be dead-center. I can't see exactly where it is coming from but the anti-freeze makes it easy to determine the approximate location.
Thanks in advance.
Phil
http://www.uniquecobra.com/
Old 01-19-2010, 10:47 AM
Rick Parker's Avatar
I once bought a product from a circle track supplier that was a round plastic (like 3/16" welding rod) that was to be "wicked" into a small pinhole after heating with a heat gun. Quick and worked well. The thin wall of the core will not normally accept the heat from any sort of torch. Maybe call a manufacturer and ask their recommendation too.
Rick
Old 01-19-2010, 01:14 PM
There was a really good shop called Capital Radiator in downtown Sac. but they went out of business, i know because i was workihg there when the owner died and his wife shut the place down.........
You might have a hard time finding someone fix an alum. rad.....
if you know which tube is leaking then you can pinch that tube
off where it goes into the header/tank on both sides......
thats probably what a shop will do because those tubes are real thin
and they would burn away when you put a torch to them.
Old 02-17-2010, 03:11 PM
pgermond's Avatar
Problem resolved - a tube of granular Silver Seal ($1.99) took care of the leak.
Phil
