Go Back   Club Cobra > Club Forums > NorCal Cobras
February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 12-17-2012, 02:19 PM
Bxx1's Avatar
Default Spf master brake cylinder
I am trying to locate a Superformance master brake cylinder that I can purchase, locally.
I have established the part #s as TRW pmk100 or Delphi LM48611 or ATE 032123-8611.3 however no one, that I can find stocks it in the USA except Hillbank, in L.A. Does anyone have any ideas besides getting the part from L.A. Hillbank has their own dealer part # which is not the factory part #
Thanks
Old 12-17-2012, 04:29 PM
Cobra Make, Engine: Superformance #522
Get a rebuild kit. Rebuilding mine this winter so send me a message if any questions.
Old 05-13-2013, 05:37 PM
Cobra Make, Engine: Backdraft, Coyote
Is this the correct part?
Old 05-13-2013, 08:33 PM
See post below...
Old 05-13-2013, 09:58 PM
I second the wilwood part. Replaced mine with the 7/8 inch bore from summit. $80.
Jim
Old 05-14-2013, 02:11 PM
Cobra Make, Engine: X Everett Morrison, X SPF 140, X SPF1823, currently SPF2778
Menace1 and jhv48:
Did the Wilwood master cylinder simply "bolt on" or did it require modification of brake lines and cylinder stroke? Did the old cap (with wiring for low level buzzer) work with the new cylinder? Wilwood part number 260-3376 looks like a single reservoir master cylinder and not the same as SPF
Thanks,
Tom
Old 05-14-2013, 07:10 PM
I mispoke. I replaced my CLUTCH master cylinder with the Wilwood unit.
Sorry if I misled you.
Jim
Old 05-14-2013, 11:49 PM
Tom, The part # I gave was indeed for the clutch master cylinder that I replaced on mine awhile back. Sorry for the wrong info. You might want to call Dennis Olthoff @ 704-647-0284 As he is always very helpful on such matters.
