1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
06-11-2009, 09:44 AM
NC
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
Poor Ed and I both have 550HP Roush 427R's w/3.46 final. Sunday we both got 21 MPG through the back woods to Murphys. We also both get about 5 to 7 in town.
With a 17 gal tank, it gets more miles per tank tank my Z3 or Tahoe. (Just for reference) If you need to go 500 miles on a tank the 22 gal is for you. tom
Tom
I miss my Tazer
06-11-2009, 09:39 PM
CA
Cobra Make, Engine: Factroy Five MKIII Roadster/ FMS 302 engine Mass-Flow injection
Check Breeze for new pumps and tanks
http://www.breezeautomotive.com/
2 fuel pumps sounds a little odd you might call Vince the old owner and ask him about that, he may or maynot know that story. Baffle loose I don't think thats normal mine was not loose just had it apart a few weeks back. Not sure loose would hurt anything really but I think the Baffle is for anti-slosh in the tank. Was your fuel gauge working when you pulled the tank ?, nows the time to service that too while the tank is out. Finding a good used late model Mustang gas tank if you want to replace it should not be too hard. Check the wrecking yards on south Sunrise. The FFR tank is the only one I've seen that would bolt right in. Some sort of fuel cell is another option but mods will probably be needed.
06-11-2009, 09:47 PM
CA
Cobra Make, Engine: Superformance 460 SVO
Ray, whatever you do, be careful working on your tank. good ventilation is a must, gas fumes are dangerous, just needs one little spark.
06-11-2009, 10:10 PM
CA
Cobra Make, Engine: FFR, 302EFI, Supercharged
Guys, Thank you all very much. I have been reading these posts all day as I have been working on the car and chasing parts hither and yon (yawn)! I replaced the pump and the tank twice! The wrecking yard gave me a tank with four locking lugs that hold sending unit and pump in and my old tank had three. Of course I didn't notice until I had cleaned it up inside and out and had put the pump in... Oops! No big I thought I'll just get the other style locking rings... Right! None of the Ford dealers carry them, the wrecker didn't have them but offered to pull a tank from a car in the yard while I wait. OK, tanks I'll wait. Hour and a half later the guy comes in and tells me that the tank had the same rings I already had, but I can have the whole tank, Cool! I traded and they took my old tank so I didn't have to deal with it, The replacment tank was real dirty on the out side only and Looked like it had pretty fresh gas in it. A quick cleaning and flush And I was back where I was only 3 hours erlier!
There is never anything easy with custom cars... except spending money and time! Why are they so much fun any way.
Got it all buttoned up tonight and went to the gas station for about three gallons, just in case, then a test ride for about an hour and a half. So far it runs better than it has since I have owned it and no leaks, time for a full tank!
The grommet on all three tanks either tore split or crumbled when I took them out of the tanks, the good news was Folsom Lake Ford sell them for only $28.xx Pls tax. 30 something for that and the seal for the sending unit, The new pump came with it's own seal. The filler neck grommet is a MUST CHANGE if the filler neck comes out, it's not worth the risk.
Again, thanks to all, I think This got it.
06-12-2009, 09:46 AM
NC
Was it the tank or fuel pump or not sure yet?
Tom
I miss my Tazer
06-12-2009, 12:29 PM
CA
Right now I'm not certain this was the problem, I guess you can say I'm cautiously optimistic!
If it is fixed I think both were contributing factors based on how the car acted. Sometimes just an occasional hiccup or hesitation and other times it would shut down and maybe just idle roughly so to speak. I think the intermittent pump would cause part of the problem and sometimes be helped along with the baffle shifting over on top of the sock/screen blocking flow. When I would jump on it it would shift the baffle away from the sock and I would get better flow. When just putting around the baffle would gradually work itself over the sock and slow flow. I think when both things acted up at the same time it would shut down and then re-prime as I was slowing down. Who knows I am just guessing.
Time will tell. Keeping the fingers crossed!
06-13-2009, 09:51 PM
CA
YeeHaww!
Went for another ride today and it is a different car! It is overall much smoother in every respect not a hickup or hesitation at all, This is a mild mannered car that runs like you would expect an EFI V8 engine to run, at least until you tickle the supercharger with the throttle toes!
I B happy now!
Thaks again!
06-13-2009, 09:54 PM
Ca.
Good job Ray. Glad you got it figured out. A lot of good referance information for everyone else also.
Terry
06-14-2009, 11:40 AM
ca
I had that same problem on my FFR. The Baffle inside the fuel tank broke free and was causing all sorts of related problems. New tank fixed it-John
"What's behind me does not matter"
Thread Tools |
Display Modes |
Rate This Thread |
Hybrid Mode
