Go Back   Club Cobra > Club Forums > NW Cobra Club
March 2025
30 31
Old 02-15-2009, 10:05 AM
ndpace's Avatar
Cobra Make, Engine: B&B with Motorsport Crate 302
Default diff drain plug
I was all pumped up and ready for my B&B to take it's first steps on it's own. I just need to add fluid to the newly installed tru-trac diff. I sent to remove the drain plug which in in the diff, not the housing, and the 3/8 square stripped (rounded). It sticks out some so I tried vise grips on it to opne and stil no luck.
Any suggestions?
I really want it to move under it's own power today
Thanks, Jim
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
01 F350 Crew Cab V10
Old 02-15-2009, 10:17 AM
Weld a bolt to it (assuming it is iron). Then replace it with a new plug.
Good luck.
Old 02-15-2009, 10:24 AM
Jerry Clayton's Avatar
remove axle on one side and add lube thru the axle hole
or thru the vent hole--usually a hollow bolt type fitting that holes the brake lines to rear
Old 02-15-2009, 11:35 AM
Rick Parker's Avatar
Heat the plug with a propane torch, then touch the outer edge perimeter with a candle an some wax will wick into the threads, allow it to cool and try agaon with the Vise Grips. Replace the plug with a steel internal hex tapered pipe plug from hardware store.
