March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 05-03-2010, 12:56 AM
westcott cobra's Avatar
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
@Fraz,
the rover switch positions turned clockwise are:
OFF Connects: 3+5, 1+6
Interm. 4+5+6
Slow 3+4+1
Fast 3+2
That means:
OFF: connected from 3 to 5, motor connection for park position, switched off by the breaker switch in park position
Interm: don't now what kind of relais do you want to use
Slow: connected from 3 to 4, motor connection for low speed
Fast: connected from 3 to 2, motor connection for high speed
Pushing the fluted knob activates the screwed in washer switch, so you can switch ground or power independend from the normal wiper switch connections to drive the washer pump.
@All,
the 2 numbers i posted for " alternative" switches are wrong. I checked all my switches at home and found out that i collected the switches just to get washer switch spares. The 35796 and 39195 are 2-speed switches but will not work with our common wiper motor. Used with the cobra wiper motor they are just 1-speeds because:
35796 internal connections turned clockwise are:
0. 1+2+3
1. 1+2+4
2. no connection
So the switch could be used counterclockwise to drive a conventionel setup not "british" wired
39195 internal connections turned clockwise are:
0. 2+3
1. 2+4
2. 1+4
Sorry for the mistakes,
Uwe
Everything should be as simple as possible - but not simpler !!
Old 05-03-2010, 05:07 AM
Hi Uwe,
thanks for the update. Would you be able to elaberate on your connections. Do you use all off the connectors? As in the 'slow' position what does 1 do/what do you have 1 connected to?
I'm pretty sure that position 1 on the P6 switch is Delay/Intermittent. Ill attach 2 pics showing it on the original and from a parts catalogue. I Intend to use the wiper delay from a Sierra. I think the P6 had a mechanical delay from a vacuum source.
Fraz
Old 05-03-2010, 05:09 AM
and the pic
Old 05-03-2010, 08:44 AM
1 and 6 i don't use
Westcott
Old 05-11-2010, 10:19 AM
39156 requires a relay circuit to park the MG/Triumph wiper motor. (Included in the ERA kit, of course...) There have been some schematic diagrams to fabricate one posted elsewhere.
Old 05-13-2010, 11:36 AM
mjhcobra's Avatar
Cobra Make, Engine: Everett Morrison, 428
I was not able to find a wiring diagram that uses a relay and this switch (39156). Please post it if you got one.
Old 05-13-2010, 12:16 PM
Smile wiper switch part number
The original wiper switch is Lucas part number 34374A model number PRS7 and the wiper motor is Lucas 75311F and the model number is DR3 this motor has 6 leads,I have Lucas model and part numbers for all the electrical parts on a cobra. Hope this helps.
Regards,
Mike
Old 05-13-2010, 01:57 PM
mjhcobra's Avatar
Thanks for the input. Sounds like some of the info in this thread may not be correct. Regardless, I am using the Lucas 14w 2 speed motor and either the toggle switch or the rotating switch. I got the toggle switch to work-parks and all with no relays. But wanted to use the fluted knob for originality. It I can get it to park great, if not the so what.
I have seen it work with wiring diagrams that use a relay and the 39156 switch, just can't find them again.
Thanks for the part numbers-that's a big help.
