March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 01-05-2011, 07:00 PM
1985 CCX's Avatar
Default 260/289 fuse box used
What are the correct fuse box and voltage regulator used for:
1) 260 cars
2) 289 cars
3) 427 cars (Bonus question)
Old 01-05-2011, 08:39 PM
LMH's Avatar
LMH LMH is offline
Hey Jeff
From my chassis manual for 289:
Fuse box is Lucas SF4
Voltage Regulator (Control Box) is RB106/2
Keep in mind that the manual shows a Lucas generator C40-1, not an alternator.
427 and 260 stuff I'm not sure of.
Alba gu brāth
Old 01-06-2011, 07:49 AM
1985 CCX's Avatar
Thanks I too have that same information in my manual.
I think later 289's used a std Ford voltage regulator, Lucas DB10 fuse box. The earlier alternator equiped 289's might have used Lucas SF4 Bakelight type fusebox?
Anyone else?
Old 01-06-2011, 08:01 AM
computerworks's Avatar
I think later 289's used a ... Lucas DB10 fuse box.
Anyone else?
The DB10 is not a fuse box, it is a "Brake Switch Override Relay"
Old 01-06-2011, 08:18 AM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Here is how a modern version of the DB10 works.
http://www.youtube.com/watch?v=hLImE...layer_embedded
Old 01-06-2011, 09:15 AM
1985 CCX's Avatar
Is the SF4 correct?
Old 01-06-2011, 11:27 AM
Dan Case's Avatar
CSX2201 - CSX2589 USA specification (COX/COB done differently) street cars used Ford supplied wiring throughout. The fuse block is a FoMoCoŽ marked molding. They are installed in just about the hardest place you can imagine to access behind the dash blocked by the steering column, dash brace, and lots of wiring loom bundle.
Dan Case
