March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 08-10-2012, 07:14 AM
xb-60's Avatar
Default Harrison tank
Any leads on the best places for sourcing a Harrison tank? I have had a brief troll around, looking. No luck so far.
Glen
Old 08-10-2012, 07:43 AM
Cobra Make, Engine: Unique Motorcars 289 FIA street version
Zip Corvettes has them date coded for 184.00 and non coded for 159.00.
Old 08-10-2012, 07:49 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
1963-1967 Corvette Expansion Tank (Replacement) | Expansion Tank & Cap | Corvette Parts and Accessories
Find a place that sells Corvette restoration parts... they were used on 1963 to ? vettes
Jack
XSSIVE .....
Old 08-10-2012, 09:25 AM
MRGEORGE077's Avatar
Cobra Make, Engine: Shelby American CSX 8000 Slab Side series, 289 High Pro , Eight Stack EFI system ,TKO500
http://www.parts123.com/parts123/yb....Z5Z5Z50000027b
Old 08-10-2012, 09:40 AM
Cobra Make, Engine: built the molds and body composite construction
ecklerscorvette.com Part #A2365---$187.99 undate coded Part #29698---$194.99 date coded, cap #25026--$31.99. Yes, these are a little more expensive than some but Ecklers will stand behing their products. Many of the bargain products LEAK and are made in the Far East.
BillK
Old 08-10-2012, 10:42 AM
Here is where I bought my replacement tank after mine started leaking
1961-1962 Corvette Aluminum Radiator Expansion Tank Replaces Original GM 3151016 made in USA
Old 08-10-2012, 01:42 PM
mickmate's Avatar
Flee bay.harrison tank | eBay
mickmate
http://www.actoncustom.com/
Old 08-10-2012, 09:29 PM
xb-60's Avatar
Thanks all. Enough leads there
Nick- I had seen the eBay listing; that one has some damage.
Glen
Old 08-11-2012, 02:48 AM
xb-60's Avatar
Default Brackets and straps....Corvette as well?
Tank mounting bracket and straps for the Harrison tank.....are they the Corvette items as well for the Cobra 289 installation?
Glen
Old 08-11-2012, 04:11 AM
Hotfingrs's Avatar
I don't know if they are correct, but I am using them. As fragile as those tanks are, I wouldn't buy a used one. I run two grounds straps also, one from battery to motor and one from motor to frame. I ruined one tank from electrolysis, in less than a year, because of not enough grounding.
Jack
XSSIVE .....
Old 08-11-2012, 04:20 AM
mickmate's Avatar
Cobra uses its own bracket and basically a long hose clamp to mount by the leaf spring.
mickmate
