March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree37Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
  #81 (permalink)
Old 08-24-2015, 10:21 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
Larry: can you or any of the other forum members tell me if the flute "valleys" of the red handled BDS screwdriver is the natural wood of the handle showing thru a clear coat or are they painted some off white color?
Thanks
Greg
  #82 (permalink)
Old 08-24-2015, 10:29 AM
Club Cobra Member
Larry. I'm sending you a PM.
Greg
  #83 (permalink)
Old 08-24-2015, 12:31 PM
LMH's Avatar
LMH LMH is offline
Looks like to me that the flutes are not painted. The wood is fairly light in color. I don't notice any clear coat as far as original goes though for a display piece, it might be a good idea.
Alba gu brąth
  #84 (permalink)
Old 08-25-2015, 12:17 PM
LMH's Avatar
LMH LMH is offline
Here's another that might be a little better.
Alba gu brąth
  #85 (permalink)
Old 08-27-2015, 07:06 AM
Club Cobra Member
Thanks Larry. Crisper and brighter. I'll see if I can get some decals printed up.
Greg
  #86 (permalink)
Old 08-27-2015, 07:13 AM
Club Cobra Member
You know, as I'm working on this screwdriver project, I wonder what AC or Shelby was thinking when they supplied that "big" screwdriver?
There couldn't have been that many slotted screws on the cars or places where you could access such a long screwdriver. Maybe it was just a pry bar in disguise.
Greg
  #87 (permalink)
Old 08-27-2015, 10:37 AM
LMH's Avatar
LMH LMH is offline
Could be.
I was thinking the decal would be best as a water slide but I'm no decal expert. What are your thoughts?
Alba gu brąth
  #88 (permalink)
Old 08-27-2015, 02:01 PM
Cobra Make, Engine: ERA Cobra #273, 427 S/O, ERA GT-40 #2057, Excalibur Cobra.
Can someone tell me the exact TOTAL length of the original screwdriver?
Thanks.
Jack
It's impossible to make anything FOOLPROOF - - Because FOOLS are so ingenious.
  #89 (permalink)
Old 08-27-2015, 02:34 PM
Club Cobra Member
Hi jack. As you can see in my post earlier in this thread, the catalogue calls out an 8" shaft and my pics show a handle and ferrule of 6" = total length of about 14".
Greg
  #90 (permalink)
Old 08-27-2015, 03:04 PM
Club Cobra Member
Hi Larry. Water slide may be better as it is so thin and may conform better to the "tulip" above the ferrule.
But if I can find a thin enough adhesive backed vinyl - we'll see.
Greg
  #91 (permalink)
Old 08-27-2015, 04:10 PM
LMH's Avatar
LMH LMH is offline
I was asking a friend if the triangle could be curved a little to make it fit the handle. He said yes but doesn't have the program to do that. I'm not sure what would be original.
On the length, original cars have been found with a couple different screwdrivers. The most common (as far as I know) screwdriver, at least from the small block car, is about 10.5" overall. (see the photo I posted from 2337) I don't know if there was a difference between the leaf spring cars and the coil spring cars as far as the tool kit is concerned though.
Alba gu brąth
  #92 (permalink)
Old 08-27-2015, 04:46 PM
Club Cobra Member
Larry. I've been using the "screwdriver in hand" photo as a guide. Sure looks like a big/long handle and long shaft so I'm guessing the 427 roadsters used a bigger screwdriver.
Greg
  #93 (permalink)
Old 08-27-2015, 06:21 PM
LMH's Avatar
LMH LMH is offline
That very well could be. Bigger screwdriver for the bigger engine!
Alba gu brąth
  #94 (permalink)
Old 08-29-2015, 09:18 AM
dblbarrel's Avatar
Cobra Make, Engine: SPF2089
If any body is interested here is a link to some tools I posted on the SAAC forum. Tom Buckus who was mentioned earlier on this thread is the owner.
I merely posted for him.
Cobra Tools
dblbarrel
  #95 (permalink)
Old 08-29-2015, 12:19 PM
Original Shelby Owner
Cobra Make, Engine: CSX 2401 street 289 Cobra and CSX 3288 Street "427" Cobra
Default Cobra tool kits
The screwdrivers were all about 10.5" in length, no difference between the kits for the 427 and 289 cars. The screwdriver had to fit in the tool kit bag, which is only about 11" wide. There were two different tool bags that I know of, one style only coming to my attention in the last year shown to me by the original owner of his car. The old bag was carefully preserved in a plastic bag. I couldn't believe it was truly a factory supplied bag until I saw another one in a 13k mile car just 3 months ago.
The kits were all basically the same with a simple steel rod tommy bar, Elora 5 wrench set BSF/BFW sizes, Thor hammer (cooper and rawhide heads), pliers (2 styles), the brake bleeder wrench and the screwdriver.
The grooves in the screwdriver handle were cut AFTER the handle was painted, amazingly. The wood was european birch, if I recall correctly from my timber expert.
The decals were water slide. The lack of the bottom of the triangle on the decal on that screwdriver is because it has chipped off over the years.
Getting a water slide decal to conform to the contours of the handle is a real trick----I have tried it many, many times. Decal Set liquid helps the decal soften and mold to the shape, but then it becomes fragile, so... lots of luck!
The shaft of the screwdriver is 7mm in diameter, in my research a very tough diameter to find. Most modern ones are 8 mm.
  #96 (permalink)
Old 08-29-2015, 12:40 PM
LMH's Avatar
LMH LMH is offline
Thanks Jim! Appreciate the info.
The one I have is 10.5" overall and the shaft measures .276". Also has "FOREGIN" stamped in the shaft.
Alba gu brąth
  #97 (permalink)
Old 08-29-2015, 03:25 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
My screw driver came from a known original owner of one 289, one street 427 and one comp 427. The screw driver that he gave me is marked "MADE IN ITALY" and the flutes in the handle are bare wood (note knot)....
  #98 (permalink)
Old 08-29-2015, 03:26 PM
.....flutes
  #99 (permalink)
Old 08-29-2015, 05:35 PM
LMH's Avatar
LMH LMH is offline
Here's what mine looks like:
A little hard to see but it says "FOREIGN" on the shaft, about 2" up from the tip. Overall length is about 10.5" and diameter is .276".
Alba gu brąth
  #100 (permalink)
Old 08-30-2015, 08:47 AM
Club Cobra Member
Great info guys. Could we get a little more?
Shaft length: from bottom of ferrule to the tip of the blade
Handle length: from the bottom of the ferrule to the end of the handle
Handle major diameter
I'm trying to tailor the screwdrivers I have to match if I can.
No, they won't be originals, they'll be "re-creations" as CS calls 'em.
Greg
Rate This Thread:
