1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
01-14-2013, 07:44 PM
SA
CSX2xxx horns
Can anybody tell me what horn(s) CSX2xxx cars had as standard? Do they sound any good?
Glen
01-14-2013, 08:08 PM
Ca
I believe they were called "Windtone Horns" Hi & lo tones.
Rick
01-14-2013, 09:39 PM
FL
Good luck finding them.
Ned Scudder
01-15-2013, 04:55 AM
SA
So what else would be period correct and could one conceivably use as a replacement on an original CSX2xxx?
Glen
01-15-2013, 02:17 PM
n/a
Cobra Make, Engine: 289 leafspring, r/p
Personally, I'd use a pair of replica Windtones:
Horns 12v - Horns & Spares from Holden Vintage & Classic
Roger
ps if you click on the horn photo you can hear what they sound like!
01-15-2013, 10:06 PM
Cobra Make, Engine: CSX 7030 HP 289
The horns were available on several different English makes of the period. A lot of the time when they do not work you can simply adjust the point gap per the Cobra chassis manual.
02-07-2013, 04:24 PM
n/a
I just got a pair of the modern repro Windtones:
Pair of Windtone Horns - Horns & Spares from Holden Vintage & Classic
...and they look very close to the one pictured in the 289 Chassis Manual.
Roger
02-07-2013, 07:50 PM
SA
Originally Posted by rsk289
That's a good feature to be able to hear them. Some are disappointingly weak, but the GBP84 pair sound good and strong
Glen
02-07-2013, 08:38 PM
AZ
I just learned something... turn the volume down on your computer BEFORE clicking that horn test button!
Alba gu brąth
02-07-2013, 08:51 PM
SA
I had earphones on, so got the full "benefit"
02-08-2013, 07:45 AM
NH
Good luck with Lucas part, model, serial, numbers names, categories etc. I believe the windtones are the 7H Lucas 7H Windtone Horn LU69152 AC Austin Jaguar Jensen MG Bentley Triumph | eBay
02-08-2013, 07:51 AM
NH
The expression "whinging pom" came to mind when I saw this at worthpoint.
Original Pair Vintage Lucas 7H Whintone 12 Volt Horn (04/22/2011)...
Classic typo on the Whintones. That is a good (bad) example of searching parts by typos for ya.
02-08-2013, 10:26 AM
Ca
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Moss Motors has replicas of the Lucas horns although there are subtle differences.
02-08-2013, 10:53 AM
Full Blown Member
Yes, but do they sound the same as originals?
Sorry, just channeling my inner Patrickt.
I gotta hand it to you guys.
rodneym
