December 2024
Old 05-11-2016, 02:10 PM
Default hood prop rod clip
looking for a correct repro clip that holds the hood (bonnet) prop rod when the hood is in the closed position. From my research it appears that it was made of a yellow plastic (white that turned yellow with age?) but I am not certain. An old post (10 years) referenced a person who had them for sale for just a few dollars. That phine number is no longer in service.
Any assistance much appreciated. The devil is in the details, right?
Best
Old 05-11-2016, 05:33 PM
LMH's Avatar
LMH LMH is offline
I've never really looked that closely at it but I think it's a flat steel hook, painted black and attached to the right hand aluminum splash panel.
Alba gu brąth
Old 05-11-2016, 07:50 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Sent you a picture via email. The original hood strut hook is a piece of metal strap, bent into a J shape and bolted to the right inner fender.
Paul
www.65shlb.com
www.prdcrrct.com
Old 05-11-2016, 09:17 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Even if mickmate (Acton Custom) doesn't advertise them, me thinks he's got it anyways.
rodneym
Old 05-12-2016, 09:31 PM
Cobra Make, Engine: Superformance 427SC/Roush 427IR
I have the same problem and look forward to seeing where these might be available.
As an interim solution, I went to Ace Hardware and bought a "j" looking clip with black rubber coating and bolted it in place. It works fine and looks ok, although not as strong as the original.
