January 2025
26 27 28 29 30 31
Like Tree30Likes
  #81 (permalink)
Old 08-10-2018, 05:05 AM
rsk289's Avatar
Cobra Make, Engine: 289 leafspring, r/p
Originally Posted by CompClassics View Post
The resistor is a back up in case the charging indicator bulb fails, this allows the charging system to continue to operate normally. If the resistor is not in the circuit and the charging indicator bulb fails your charging system will not operate. Since the bulb does not illuminate in this situation you may or may not realize that the fault with the system is the bulb and not another component in the charging system.
Thanks, that makes sense. For some reason UK customers don't get the failsafe! I don't think any of my older Brit sportscars had a resistor in parallel, although some MGs etc. did have a fine restistance wire wound around the warning light casing which was presumably there for that purpose. None of the later Healeys or TRs did, though - pretty sure original Cobras didn't either. Obviously this is for cars with Lucas electrics, not Ford/Autolite.
CompClassics likes this.
  #82 (permalink)
Old 02-06-2019, 05:38 AM
ALF's Avatar
ALF ALF is offline
Still struggling with my setup…
Can anyone tell me the difference between a D4TZ10316A and a C5AF-10316-A Regulator?
I got told I need to change my Regulator to a D4TZ10316A to match the Alternator which is a Thunderbird C3SF-10300-A Version…..
But at the end they are all doing the same (Field Relay; Voltage Limiter)??
The point I’m struggling at the moment is the following:
Is it correct that the Alternator provides 12V on the Neutral Terminal as soon the Output Terminal gets 12V+ connected?
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
  #83 (permalink)
Old 02-06-2019, 05:44 AM
Senile Club Cobra Member
Alf,
The D4TZ regulator is an electronic version, the C3SF is mechanical. Generally you can substitute an electronic unit for a mechanical. You can remove the cover of the electronic and replace with the mechanical to gain a closer to original appearance. There are several reproduction regulators that have the tall cover with the "IASF" stamped into them that have electronic guts.
rick@autoventureusa.net
  #84 (permalink)
Old 02-06-2019, 06:00 AM
ALF's Avatar
ALF ALF is offline
Hi Mark IV
My main question is DO I NEED TO REPLACE the mechanical C5AF-10316-A Regulator with an electronic D4TZ10316A Regulator to work with my Thunderbird C3SF-10300-A Alternator....
I would say NO and the guy told me rubbish.
As I was hoping to get an answer on my "Neutral Terminal" question (as on post 82) and I got only the information that my wiring and the regulator are incorrect.
  #85 (permalink)
Old 02-06-2019, 07:05 AM
Originally Posted by ALF View Post
Hi Mark IV
No, you do not need to replace it.
  #86 (permalink)
Old 02-06-2019, 07:40 AM
ALF's Avatar
ALF ALF is offline
As expected!
Thanks
  #87 (permalink)
Old 02-06-2019, 08:15 AM
ALF's Avatar
ALF ALF is offline
After looking some great videos from MOSS on Youtube and googling I think (hope) I fund the issue!
I need to adjust the field relay on the regulator to stop closing the contact immediately after the battery is connected to the alternator. It needs only to close after the alternator is running and producing power!
I found a value of > 6V measured on the S contact of the regulator. (But I hope someone can confirm this Volt value)
  #88 (permalink)
Old 02-06-2019, 09:53 AM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
ALF,
You should pick up one of these manuals, great information and wiring diagrams.....
https://rover.ebay.com/rover/0/0/0?m...2F382760249638
  #89 (permalink)
Old 02-06-2019, 11:16 PM
ALF's Avatar
ALF ALF is offline
Hi John
Many thanks for the recommendation.
I'm in contact with the seller to get the shipment to Europe enabled.
  #90 (permalink)
Old 02-07-2019, 11:48 PM
ALF's Avatar
ALF ALF is offline
The manual is on the way!
Now I need to wait some weeks and after that I'll know the Volt value the Field Relay has to be set.
  #91 (permalink)
Old 02-08-2019, 02:18 PM
Cobra Make, Engine: ERA 3012
PM'd you.
  #92 (permalink)
Old 02-09-2019, 12:46 AM
ALF's Avatar
ALF ALF is offline
Thank you for the PM
Not less than 3V or mire than 4V
