November 2024
Old 06-10-2008, 09:28 AM
Larry N Johnson's Avatar
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Default Wiper Control Switch
Where can one get the correct wiper control switch for the correct knob that twists? The CSX cars has a 3-position twist type switch: off-on-on for park-normal-high (speeds), like this:
Finishline sells a wiper kit that uses a 3-position toggle switch, as does Kirkham.
Getting the CSX knobs is not the problem; it's the switch.
Any ideas or suggestions appreciated.
Old 06-10-2008, 12:54 PM
289ACE's Avatar
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
Larry, I believe the switches are the same as what was used on Aces and Ron Leonard (Sport and GT) used to carry them.
He is in Durango, Col and can be reached at 970 259-0108
Jay
Old 06-10-2008, 12:56 PM
Default Ace
Jay,
Makes sense that the switch was used on an Ace. Thank you.
Old 06-10-2008, 01:09 PM
computerworks's Avatar
Larry - good luck.
Took me quite a while to find the original one... there are several variants that have the same "positions," but with different terminal connections. (screw-type vs.push-on, I believe)
If you are doing your own wiring teminations...either would work.
I think the one that has the "wrong" type (wrong in the sense of an original harness, but electrically correct) was used in the early Jag as well.
Old 06-10-2008, 01:51 PM
Cobra Make, Engine: HI-TECH 289 FIA
Superformance has a lookalike. The switch is actually a VW unit from about 1967 with a Lucas knob.
fiaroadster
Old 06-10-2008, 03:47 PM
Default switch
Hello Ron!!
Are you coming to the June 08 Kirkham event?
Thanks for the help on the switch.
Rick,
Thanks for the help, very good suggestion.
Old 12-08-2009, 07:51 PM
Default wiper switch
I got mine from cobrarestorers.com
good luck
Dan
Old 12-14-2009, 02:56 AM
PANAVIA's Avatar
cobrarestorers.com - them be some good folks. -- we use em all the time.
