1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
03-04-2009, 09:06 PM
NH
Thanks guys some good info. It appears that a lot of this stuff is available but as suspected it is pricey, hard to find and not all available from one vendor. It didn't give much info on them in the chassis manual. Larry can you just turn your vents around? Sounds like you have the correct knobs what are they from any idea? I had a feeling a group buy would be difficult to coordinate as we had differences from the git go with me being street dash and no one wanting to shell out $300 for two switches. We'll persevere on it though.
03-06-2009, 04:18 PM
ca
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
I finally had a chance to check the air vent knobs that came with my Ace (they are not installed yet) and they are the "PULL" version. The package they came in has a receipt from Moss Motors and says they are from an Austin Healey 100-6 and 3000. The P/N in the Moss catalog shows 635-510.
Jay
03-06-2009, 06:55 PM
AZ
I have a broken one and it says "Pull" however, after thinking about it, I think it would be better to have the vent open with the knob pushed in. Here in Tucson, the vent needs to be open most of the time and you'd be running around with the knob in the way if were open/pull. So probably open/push would better.
I'm going to have to fab up the vent controls anyway (thank you Paul!), I can set it up to work either way.
What mine are from, I don't know for sure. I just collected them along the way somewhere.
03-06-2009, 07:07 PM
MO
Cobra Make, Engine: Hurricane - FE
Another Source
I have found many of the pieces you are looking for are available from Superormance. If they are clones, they've done a very good job. I purchased my dimmer, heater and wiper knobs from them
My air vent knobs came from VictoriaBritish. You'll need to take your chances on the quality. Some are engraved and filled with white, others are just hot-stamped with white.
Paul
03-06-2009, 08:02 PM
NH
Jay that's super info thanks. Look at these Hurricane guys go huh! Someone else suggested the SPF stuff as it sure looks the part. It looks like when we have a good list of who to hit up for parts we'll make ourselves a list of who's needing what. I did hit a couple of couldn't resist buy it now e-bay items and have e-mailed a good e-bay supplier from England to see about some group buy action but haven't heard back yet. http://stores.ebay.com/Classic-Bits_...QQftidZ2QQtZkm I have a couple of the footbox vents that Karl wants off me but before he gets them I'll be making those if anyone else will be needing them. Hopefully the cables and cable hardware is available from Moss or whoever we get pulls/pushes from. This is looking good guys, we'll keep it moving.
03-06-2009, 08:27 PM
ca
Nick, I have found Moss has many things that seem to be "correct" but matching them up is difficult from the drawings on their web site and in their catalog. Luckily, I work about 2 miles from their west coast store and so I can always go in and compare parts before buying. If there are any parts that need to be matched, let me know and I'll see if I can find an available option. BTW, for the vent cables, the ones Moss has are too long, but can easily be cut down with a bicycle cable cutter (cuts the outer sheath without damaging the inner cable) and be made to fit perfectly.
Jay
PS It looks like my other project will be proceeding so I'll be calling soon on some outriggers.
03-06-2009, 09:02 PM
NH
Jay that's all good news. Hey I just thought of a good local guy for bicycle cable supplies and hardware thanks for the idea. I'll be in touch.
03-06-2009, 09:51 PM
CA
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Nick,
Are you going to start making those footbox vent valves like the one I had in the box you inspected while you were out here? If it's a dead ringer, I will be in the market for another one.
Tom
03-06-2009, 09:55 PM
NH
Hi Tom, good to hear from you. It would be a dead ringer and a good discount for you if I can borrow that one for a few days........Any progress on your other project?
03-06-2009, 10:12 PM
AZ
Hey Paul
Speaking of footbox vents, I was glancing at your site but didn't see your version to fit Hurricane. Is that on your site or do have any plans?
03-07-2009, 07:13 PM
TX
Based on this thread Headlight and instrument light switch question Jeff references these part numbers, 3R 78405 for the dimmer and PRS7 54033632 for the rotary 3 position wiper switch. I found both of them new on ebay from the seller Nick mentions above, ClassicBits in England. Took about 10 days to arrive, $133 USD for the pair, delivered. I already had the Lucas knob from Moss and I found the Lucas wiper connector from Josh at www.britishwiring.com. , item #805.
03-09-2009, 12:06 AM
AZ
Ignition switch question:
Does anybody know if Lucas made an ON/OFF keyed switch? Part number?
Hopefully one that has the smooth outer mounting ring with the two slots in it like the three position switch.
I'm using a seperate push button starter switch and would like have a an accurate looking, ON/OFF-only ignition switch.
03-16-2009, 12:29 AM
AZ
Hey all
Another dash item that I'm looking for is the small indicator lights mounted on the dash. Does anybody have a source for the correct ones?
03-23-2009, 08:43 AM
UK
If cobra restorers cant help you, then this side of the pond theres
https://www.europaspares.com/COBRA_S...GHTS_2406.html
or Hawk as mentioned previously.
03-23-2009, 02:29 PM
AZ
That's them Kevin, thanks! CR does sell lights but they aren't the original type.
03-23-2009, 03:03 PM
WOW! $27 a piece for those little things...........
03-23-2009, 03:13 PM
UK
My Dad got me one for christmas - i'm saving up for the others!
to misquote one of my favourite old tv series.. cobras cost, and this is where you start paying.
03-23-2009, 04:16 PM
Air vent says "PULL" to close the fresh air !!!! The small indicator lights are made by HAWKCARS they sell them to all others !!!!
Fritz
HAWK CARS LTD. GERMANY &
KIRKHAM MOTORSPORTS EUROPE
03-28-2009, 08:18 AM
UK
In case anyones interested, all the Lucas part no.s you'll need...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=270362040166
I've just been outbid up to my max! not prepared to go any higher.
cheers,
Kevin
05-13-2009, 04:29 PM
Cobra Make, Engine: AC Superblower (part built)
Hi folks, I have read this thread with intertest as I was myself trying to obtain the authentic looking Wiper and Dimmer rotary switches. They were hard to source, however as mentioned earlier in this thread, Superformance can supply the required parts. I contacted a chap named David Cope from Millbank Motorsports Inc- I believe they are Superformance distributors. He sent me the following information regarding the parts he could supply to me including specific Superformance part numbers and prices. I hope this information is of value to you all!
WIPER SWITCH
00-010-00155 SWITCH WIPER $181.63 ea.
00-010-00041 KNOB WIPER $ 7.93 ea.
00-033-00146 NYLOC S/S 3MM $ 0.25 ea.
00-033-00856 WASHER S/S 3MM $ 0.12 ea.
00-033-01334 BUTTON HEAD SCREW SS, 3 X 6MM $ 0.25 ea.
POSITION SWITCH
00-010-00341 KNOB, DISTRIBUTION SWITCH $ 7.93 ea.
00-010-00332 RETAINER, Ø12 x M14x1 x 12.5mm $ 3.61 ea
00-033-00851 CHEESEHEAD SCREW ZP 3 X 20MM $ 0.25 ea.
00-010-00339 BRACKET, DISTR. SWITCH Y/P $ 18.20 ea
00-010-00334 INSERT, WIPER SWITCH $ 7.93 ea.
DIMMER SWITCH
00-010-00534 SWITCH, DIMMER DASH $94.48 ea.
00-010-00040 KNOB, DIMMER $ 7.93 ea
00-010-00335 RETAINER,HEAT FAN/DIMMER $ 1.29 ea.
00-033-00437 GRUB SCREW BLACK 4 X 8MM $ 0.25 ea.
FAN SWITCH
00-010-00630 SWITCH 3 POSITION $ 8.73 ea.
00-010-00340 KNOB, INTERIOR FAN SWITCH $ 7.93 ea.
HEADLIGHT SWITCH 00-010-00092 $125.18 ea.
WASHER PUMP SWITCH 00-010-00331 $101.73 ea.
Regards
Gary
