December 2024
Old 03-12-2009, 06:27 AM
Default Radiator Color
Were the original big block car radiators: natural brass, natural aluminum or painted black? If painted were they flat, satin or gloss?
Thanks,
David
Old 03-12-2009, 08:42 AM
mickmate's Avatar
Hi David, the ones I've seen are black with whatever is left of a gloss after quite a few years and heat cycles.
mickmate
http://www.actoncustom.com/
Old 03-12-2009, 08:49 AM
Default Original Radiator
My radiator (not currently installed) is a Lauck unit of copper and brass construction it is 24" wide x 18" high with a 3.25" core it is painted a black that is sort of a combination of flat and satin.
PS painted radiators are a bad idea for cooling, my car used to over heat all the time until I put in an aluminum radiator with "turbulator" tubes fabricated by Roush racing.
Old 03-12-2009, 08:58 AM
wtm442's Avatar
Beam Me Up Scottie
You beat me too it.
NEVER paint a radiator
Every coat of paint reduces the efficiency of the radiator by a lot. Its just like adding insulation to a radiator.
Warren
Old 03-12-2009, 09:00 AM
Looks like NO PAINT for me!
David
Old 03-12-2009, 09:30 AM
mickmate's Avatar
The guy from Fluidyne told me painting it is fine as long as you don't make it 1/4" thick. I would avoid a high gloss paint as it would reflect heat back in like chrome and polished surfaces, conduction, convection and radiation right. David if you have the HiTech brass one it will conduct heat (cool) better than an aluminum one anyway.
mickmate
Old 03-12-2009, 09:38 AM
I actually do have a brass unit which has been moth-balled for most of my ownership of the car. I replaced it early-on with an aluminum unit.
Eastwood has a radiator paint they tout as not affecting heat exchange like regular paint does. I had considered using it on the brass radiator and aplying it as sparingly as possible.
David
Old 03-12-2009, 09:41 AM
convincor's Avatar
Cobra Make, Engine: FFR 390 toploader IRS
this topic came up before, maybe not here but. I guess everone has an opinion..
From the thread linked-
"My Bro in law works for an outfit that fabricates radiators for NASCAR, IRL, etc. He told me they have run tests before and found that radiators painted black are slightly more efficient than if left in bare aluminum."
http://www.jalopyjournal.com/forum/a.../t-151362.html
FFR MarkIII,FE,toploader,IRS,3.27,Vintage pin's SOLD!
68 F100 Custom Cab 418 cube FE/auto
99 SuperDuty Tuner/chipped/4" Banks TOTALED!!
02 Super Duty 7.3L
Old 03-12-2009, 09:43 AM
Amazing. Seems if we look long and hard enough, we'll find the answer we want, whether right or wrong.
David
Old 03-12-2009, 09:55 AM
convincor's Avatar
yep, and who's to say which it is.
02 Super Duty 7.3L
Old 03-13-2009, 08:55 AM
If we are talking aluminum radiators, look in to having it anodized black instead of painted. The anodizing shouldn't cause any insulation effect and black definitely radiates heat better than natural aluminum.
Kevin
Old 03-13-2009, 03:35 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
The neatest radiator I've seen on a Cobra was painted black but the owner had masked out a large skull on the front before painting it. Imagine having THAT Cobra coming up behind your 'Vette!
Bill Stradtner
Old 03-13-2009, 04:02 PM
To throw another element besides color into the discussion; the orig. rad in my early ERA was copper/brass and weighed 31 lbs. I R & R'd with the current spec all aluminum Griffin made for ERA which weighs 15lbs.
Also cools substantially better because it sheds heat more quickly than the old.
Neither were/are painted.
Chas.
Old 03-13-2009, 07:40 PM
mickmate's Avatar
Radiator shops, OE suppliers, anyone building cars have painted radiators since there were radiators. They don't spend money unless it's justified and they certainly don't do things that don't work. Aluminum has become more cost effective to produce, hence its popularity with manufacturers. It is less efficient for radiators and needs a bigger radiator for the same heat transfer.
http://www.copper.org/applications/a...ml#performance
mickmate
