1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
07-04-2003, 04:48 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Side pipes
Anyone with any side pipes laying around that'll fit a CR or even be close? New, used, old style mufflers....I don't care....mine have all but had it....need to change.
Email fxbill@attbi.com
Thanks!
Bill
07-23-2003, 09:36 PM
MN
Cobra Make, Engine: Owner, Classic Roadsters II
Bill, I have 2 used sets, one painted with ugly mufflers that need to be replaced, the other set with new, loud, free flowing mufflers that have been Jet Hot coated bright silver.
$150 for the painted set
$450 for the Jet Hot set, 500 miles of use
$350 for a new set, unpainted with new style free flow mufflers
Don
07-23-2003, 10:32 PM
Ca
Thanks Don.... I'll take the used hot coated set for $450. Will call you Thursday or Friday to arrange pmt. and shipment. Do these have the same mufflers as the new set of unpainted?
I appreciate it....
07-23-2003, 10:35 PM
Club Cobra Member
ca
Cobra Make, Engine: Former Everett-Morrison,428SCJ
Hi Don,
I'm in search of parts to build a set of stainless side pipes for my E-M. I've found 90 degree bends, and turnouts, but I can't find collectors and mufflers.
Have you got any laying around the shop, or do you have any idea who might???
Thanks!
Jon
07-24-2003, 04:09 PM
MN
Jon, I don't have any info right now but I am having a meeting next week to discuss supplies for the pipes I make. The company has stainless available and will make mandrel bends up to 3" diameter. They make their own mufflers in steel or stainless any size you want. I would suggest you call them direct for your needs since I'm sure they are different than what I use. The company is Cremco, located in Paynesville, MN. The number is 800-642-0105. They should be able to get whatever you need.
Don
HTML code is On
