January 2025
26 27 28 29 30 31
Like Tree163Likes
  #201 (permalink)
Old 09-18-2017, 01:51 PM
ACHiPo's Avatar
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
I thought I remembered you posting the color, but I couldn't find it. What's the color name and code for the paint?
  #202 (permalink)
Old 09-20-2017, 02:17 PM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Front quick jacks finished and installed.
Paint color is Viper Red.
  #203 (permalink)
Old 09-22-2017, 06:24 AM
ACHiPo's Avatar
Nice�� And thanks for the color info
  #204 (permalink)
Old 05-12-2018, 05:07 AM
cobrakiwi's Avatar
Cool
Whats in the big box?
Looks FE,
  #205 (permalink)
Old 05-13-2018, 11:17 AM
Cobra Make, Engine: Scratch Built with 482 FE
Looks like that one is coming together nicely! Wow that motor looks clean too!
SB
  #206 (permalink)
Old 06-13-2018, 12:10 PM
cobrakiwi's Avatar
Engine and gearbox in, time for more pipe work.
  #207 (permalink)
Old 06-13-2018, 12:36 PM
1795's Avatar
Craig,
Looks good. All sorts of room to work with in there Looking forward to seeing those custom made pipes.
Jim
  #208 (permalink)
Old 06-17-2018, 04:57 AM
cobrakiwi's Avatar
Craig,
Jim
Thanks Jim
Drivers side complete
Dominik, Blue66, ACademic and 2 others like this.
  #209 (permalink)
Old 06-27-2018, 03:37 AM
Gaz64's Avatar
I see a lot of effort in the primaries, but I don't like the collector.
Trubble likes this.
Gary
  #210 (permalink)
Old 06-29-2018, 06:49 PM
cobrakiwi's Avatar
Wink
Well its hard to please everybody
  #211 (permalink)
Old 06-29-2018, 06:54 PM
cobrakiwi's Avatar
Maybe you'll like them now that the pipes are coated?
Buzz and Gaz64 like this.
  #212 (permalink)
Old 06-29-2018, 10:58 PM
Dominik's Avatar
Default header gasket
If you like advise on header mounting, read on. If not ignore me :-)
Think flanges, 3/8" - done
individual header pipes - done
Studs with ARP serrated nuts - almost done ;-)
No fixed connection to collector/sidepipe to keep the vibrations away - done
No gasket! (worked for me)
This way the flanges sit from day one. May not work if your sidepipes are very restrictive
To fit the sidepipes once the header pipes take a set, and may warp a bit, I let 3 of 4 loose, slide them into the collector and tighten the primaries. This is when no gasket helps. I also had the slip-in length slighlty different so that one after another can be pushed in.
Buzz likes this.
If I don't respond anymore, that's because I can't log in
  #213 (permalink)
Old 06-30-2018, 07:43 AM
cobrakiwi's Avatar
Allways open to advise, if I think it makes sense and would make my job easier I'm all for it.
  #214 (permalink)
Old 07-01-2018, 04:39 AM
Gaz64's Avatar
Yes I do.
cobrakiwi likes this.
Gary
  #215 (permalink)
Old 07-01-2018, 06:32 AM
cobrakiwi's Avatar
Yes I do.
Nice
The pipes went together nicely, no issues with fitting the primary pipes to the side pipe collector.
Fit and finish are spot on.
Compared to some of the other junk I've seen come in here I take these pipes all day long.
  #216 (permalink)
Old 07-01-2018, 07:42 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
The car is wonderful. The details are just incredible.
I really like the color. You mentioned Viper Red, but I don't see the code. Please post it if you don't mind.
John
  #217 (permalink)
Old 07-02-2018, 05:24 AM
cobrakiwi's Avatar
John
Thanks John,
this car is coming along super nice.
The paint I was told is PPG viper red, I don't have the code but will ask the painter for it.
  #218 (permalink)
Old 07-03-2018, 09:07 PM
Gaz64's Avatar
Looks really good now.
I'd like to see some heat shielding over the master cylinders.
Gary
  #219 (permalink)
Old 07-04-2018, 06:30 AM
Craig makes these. It is shipped with a very nice insulating material that is applied to both sides. The insulation wasn't yet installed when this photo was taken.
David
cobrakiwi and Gaz64 like this.
  #220 (permalink)
Old 07-06-2018, 11:10 AM
cobrakiwi's Avatar
Here we have one of my oil puke tanks / catch can mounted.
Drilled and tapped the gearbox breather location, made up the fitting to connect the hose to the puke tank.
1985 CCX likes this.
