April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree163Likes
  #21 (permalink)
Old 09-13-2012, 11:08 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Default hood and trunk
Here I have made the hinges for the hood and trunk along with the brackets for the latches. Then mount the hood frame.
  #22 (permalink)
Old 09-13-2012, 11:13 AM
cobrakiwi's Avatar
Default trunk
Then I mounted the rear trunk frame etc.
  #23 (permalink)
Old 09-13-2012, 01:12 PM
LMH's Avatar
LMH LMH is offline
Nice! Maybe I missed it but where did the AL body come from? Did you build that too?
Alba gu brąth
  #24 (permalink)
Old 09-13-2012, 06:09 PM
KarlCSX2498's Avatar
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Default Outstanding project
Hello, Very nice, those fotos bring back a lot of memories from my build.
One thing you need to check. In post 147, the last foto showing the trunk frame. The bottom tube needs to be held up off the lower frame tube to allow enough space for the trunk handle & latch. The measurement is approx. 1.25 - 1.5" I can check that on CSX2498 if needed.
good luck, Karl
  #25 (permalink)
Old 09-14-2012, 07:14 AM
cobrakiwi's Avatar
Larry, the body is one I have for a different project, just used it to see how it would look and fit.
It is hanging back up on the wall now.
Karl, thanks for keeping an eye on things. I really like input from others more info and eye's on some thing is all way's good. I have a good inch or so gap between the two. I did set up the latch to make sure it would work. I think if you look at pic two you can see the gap better.
Thanks for looking and offering help.
  #26 (permalink)
Old 09-14-2012, 07:22 AM
cobrakiwi's Avatar
Default More Brackets
Now we are putting the last few brackets on the frame, passenger foot box support, roll bar mount, rear trailing link mounts, and there is a pic of the tko trans mount.
  #27 (permalink)
Old 09-14-2012, 07:30 AM
cobrakiwi's Avatar
Default Last Brackets
Here I have made the supports for the side windows, they are welded to the door frames and rear body frame support. The Last bracket to be welded on is the hand - park brake handle bracket. Next was to go and check every weld and make sure i did not miss any thing. It is nice to be done with this part of the build.
And that is how you build a 427 cobra frame, at least in my shop.
  #28 (permalink)
Old 09-14-2012, 09:59 AM
LMH's Avatar
LMH LMH is offline
I've heard rumor of one of the manufacturers like Kirkham or Shelby modification or someone, making the TKO mount removable on an original style frame.
I haven't seen any pics though but wondered if you had thought about that during your build.
Alba gu brąth
  #29 (permalink)
Old 09-14-2012, 10:22 AM
cobrakiwi's Avatar
Default Trans mount
You are correct, my csx4000 from South Africa has the removable cross member that the Trans mount is fixed to. I did think about doing that on this frame but thinking about it for a week or two I decided pulling and installing the Trans from inside the car is not that bad of a job. I do not think Kirkham is making the removable cross member, but I could be wrong. I have some pictures of the removable cross member, I will try and find them.
  #30 (permalink)
Old 09-14-2012, 02:21 PM
I have a buddy who has a couple Shelby frames and they both have the removable transmission crossmembers. If I had seen it sooner, I would have made the modification to my chassis while it was easy. As said above, it really isn't too bad taking the tranny out from the top so I'll just leave it for now.
Bob
  #31 (permalink)
Old 09-14-2012, 02:57 PM
cobrakiwi's Avatar
Default csx 4000 cross member
Here is a few pic's of the removable trans mount/cross member on my csx 4000
car. I made a couple of mods to this one as I was going to run a Richmond but then changed it to a TKO 600.
LMH likes this.
  #32 (permalink)
Old 09-14-2012, 09:23 PM
LMH's Avatar
LMH LMH is offline
Interesting! Thanks for posting those. I hadn't seen what it looks like though I can see what you guys are saying about ease of install w/o it being removable.
Alba gu brąth
  #33 (permalink)
Old 09-16-2012, 04:40 PM
cobrakiwi's Avatar
Default Loaded up
I have the frame all loaded up and ready to be powder coated.
  #34 (permalink)
Old 09-21-2012, 12:37 PM
cobrakiwi's Avatar
Default powder coating
Frame back from powder coating, the company I used did a great job I think.
It all so helped the manager was a big fan of the cobra so he priced the job right. I think it has turned out great now we can start bolting on parts.
  #35 (permalink)
Old 09-22-2012, 09:03 AM
cobrakiwi's Avatar
Default Parts install
Here I have installed the steering rack, stainless brake lines and master cylinders.
alfy65 and prp289 like this.
  #36 (permalink)
Old 09-23-2012, 06:16 AM
cobrakiwi's Avatar
Default front control arms
Here we install the upper control arms
alfy65 likes this.
  #37 (permalink)
Old 09-23-2012, 06:24 AM
cobrakiwi's Avatar
Default lower
Now the lower control arms get installed. As with the upper arms,
pressing in ball joints and trying not to damage the powder coating was fun!
alfy65 likes this.
  #38 (permalink)
Old 09-23-2012, 03:01 PM
cobrakiwi's Avatar
Default rotors and pin drives
Now I installed the uprights, brake rotors, and calipers. Then the front coil overs, now the front end is almost ready for wheels and tires.
  #39 (permalink)
Old 09-23-2012, 09:34 PM
LMH's Avatar
LMH LMH is offline
Nice! Are the spindles Shelby?
Alba gu brąth
  #40 (permalink)
Old 09-24-2012, 12:04 AM
streetbeast's Avatar
Cobra Make, Engine: Street Beast, 427FE Replica (390 Block)
Cool
Nice work cobrakiwi..
Dragon427 likes this.
Rate This Thread:
